It is currently Thu Aug 20, 2026 11:09 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2, 3  Next
 Post subject: Comix Text Bubble Rel5
PostPosted: Wed Oct 17, 2012 1:03 am  (#1)
Now I can legitimately add the terminology Text to a bubble script
; Rel 0.02 - Added an additional width and height setting to accommodate long text strings
; Rel 0.03 - Changed the script to function on a active drawable and moved to Filters>Decor
; Rel 0.04 - Added extra pointer orientation options and no pointer to pointer type also a blank text box allowed for pictures
(just set add-width and add-height to required size)
; Rel 0.05 - Added shape hugging choice to bubble shapes, also added control for outline size
Menu location is Filters/Decor/Comix Text Bubble
Please replace any previous version with this more complete release
Open your Image or select layer and run 'Comix Text Bubble' to place the Bubble at the top-left corner
Move your Bubble layer to desire location and merge down for your final Image
Comix Text Bubble Rel5.zip [2.88 KiB]
Downloaded 806 times
 Post subject: Re: Comix Text Bubble
PostPosted: Wed Oct 17, 2012 1:07 am  (#2)
Thanks Graechan they are both very nice scripts.
PostPosted: Wed Oct 17, 2012 6:01 am  (#3)
Thank you Rod I hope everyone enjoys both scripts
PostPosted: Wed Oct 17, 2012 9:43 am  (#4)
graechan: thank you so much for making these two scripts, i've always made my speech bubbles by hand and they never looked good.
PostPosted: Wed Oct 17, 2012 10:27 am  (#5)
:tyspin Graechan!
PostPosted: Wed Oct 17, 2012 4:44 pm  (#6)
tried the scripts and enjoyed them very much :)
PostPosted: Wed Oct 17, 2012 5:14 pm  (#7)
PostPosted: Wed Oct 17, 2012 6:01 pm  (#8)
and thank you for all your Great scripts
 Post subject: Re: Comix Text Bubble Rel2
PostPosted: Wed Oct 17, 2012 7:31 pm  (#9)
Rel2 has just been posted to prevent this
It can now be adjusted to this
PostPosted: Wed Oct 17, 2012 8:07 pm  (#10)
That works better. I kept the layers on one of these and moved the text down even farther. The top one is as it came from the script.
PostPosted: Wed Oct 17, 2012 9:47 pm  (#11)
Another way is to input a space on first line and Halloween on the second then image on the third
sorry but I don't have the font, please use your imagination
 Post subject: Re: Comix Text Bubble Rel3
PostPosted: Fri Oct 19, 2012 1:41 am  (#12)
Rel3 has just been posted and runs on an active layer or Image
PostPosted: Fri Oct 19, 2012 3:51 am  (#13)
:tyspin You Rock :yes
PostPosted: Fri Oct 19, 2012 10:54 am  (#14)
What fun!! Thanks, Graechan! :yr
PostPosted: Fri Oct 19, 2012 10:57 am  (#15)
O: i love that! and graechan's script of course, i've had some good fun with it :)
PostPosted: Fri Oct 19, 2012 7:23 pm  (#16)
Thank you Molly, 'O' and Anmal. It''s been fun writing this script as it fills a niche that has existing ones that don't foot the bill.
PostPosted: Fri Oct 19, 2012 9:13 pm  (#17)
Well, I finally got around to playing a bit.
PostPosted: Sat Oct 20, 2012 3:40 am  (#18)
Odin your Penguins are fantastic, did you flip the bacground-bubble layer
that's an Idea that's worth pursuing
PostPosted: Sat Oct 20, 2012 4:54 am  (#19)
PostPosted: Sat Oct 20, 2012 12:18 pm  (#20)
Yes, I kept the layers, flipped the background, merged text, scaled layer. Great script, great fun!
