It is currently Tue Aug 18, 2026 2:33 am
 Post subject: CSI-style super-resolution image enlargement? Yes?
PostPosted: Mon Dec 10, 2012 11:55 pm  (#1)
are there any algorithmic plugins that can smoothe blocky pixels same as explained on this website:
http://www.extremetech.com/extreme/1329 ... t-yeeaaaah
what are the best super resolution processes in gimp?
 Post subject: Re: CSI-style super-resolution image enlargement? Yes?
PostPosted: Tue Dec 11, 2012 12:14 am  (#2)
ok i found the enlarge and sharpen plugin :)
PostPosted: Tue Dec 11, 2012 1:07 am  (#3)
If there was an uploaded image you wanted to enlarge and increase its resolution quality you'd probably get more replies.
Enlarge and sharpen isn't that good for n-fold enlargement and more likely to disappoint you. It is okay for .n image upscaling, tho.
And it is definitely not the same as single image SR.
PostPosted: Fri Dec 14, 2012 7:24 am  (#4)
I wonder how Super-Resolution method turns out when used for printing images, because when I see the result on a monitor, though clearly enhancing the original image, doesn't really make the image appealing to me, it's a kind of a "less worse than bicubic" method to me.
PostPosted: Fri Dec 14, 2012 9:04 am  (#5)
Qu'en termes élégants ces choses-là sont dites :)
PostPosted: Fri Dec 14, 2012 11:19 am  (#6)
You have to click on colored buttons on the right side of magnified image to see the results.
The names on those buttons correspond to resolution enhancement method.
The SR results from this page were discussed on gimp-mailing list a few moths ago.
Some people found the results too good to be true. But who knows?
PostPosted: Fri Dec 14, 2012 11:52 am  (#7)
Check out the thread on this very subject that I started a few months back. :)
http://gimpchat.com/viewtopic.php?f=4&t=4762
