It is currently Thu Aug 20, 2026 11:54 pm
 Post subject: Script for superpixelchris
PostPosted: Sun Jan 27, 2013 6:25 am  (#1)
First of all I apologise to everyone for doing this, but I see no other option, and it's seems like the right thing to do to introduce someone new to this place.
I was trying to help someone on GimpTalk by writing a script for them: http://www.gimptalk.com/index.php?/topi ... -paid-job/
But GimpTalk is miss-behaving again, so I'm posting it here instead.
I run it using a batch file (.bat) containing the following line:
"C:\Program Files\GIMP 2.8.2\bin\gimp-console-2.8.exe" -idf --verbose -b "(batch_spc2013 \".png\" \"processed\" '(0 255 0))" -b "(gimp-quit 0)"
Which is in the directory containing the files you want to process and create a directory called processed to put the resulting files into. I've done it this way because I have philosophical objections to overwriting original files.
Kevin
spc2013.scm [3.54 KiB]
Downloaded 107 times
 Post subject: Re: Script for superpixelchris
PostPosted: Sun Jan 27, 2013 5:41 pm  (#2)
You can try again Kevin; just visited there a few minutes ago; must have only been a few hours blip (better then a few weeks one). :)
PostPosted: Mon Jan 28, 2013 1:58 am  (#3)
Lyle, the site was up and I could post replies, but I couldn't attach a script file (or get a readable error message) and when I tried to post a listing inside "[" code "]" tags it changed my code, so no-go.
Kevin
cron
