It is currently Tue Aug 18, 2026 3:32 pm
 Post subject: error in gimp loader for python plug-ins ?
PostPosted: Tue Feb 19, 2013 5:01 am  (#1)
Hi to everybody who writes plug-ins (in python) or has to do with gimp loader.
I like to explain to you what IMHO is a behavioural error in gimp loader when loading python plug-ins:
- if you have a python plug-in already tested and running and you close gimp, edit the plug-in changing the menu path (neither the file name nor the plug-in name, just the menu path), gimp does not recognize the change and your plug-in still appears under the old menu path (even if you check help/plug-in browser you find it detailed as before the change); if you want your change taking effect you have to close gimp, edit the file .gimp-2.8/pluginrc, remove the lines related to your plug-in and restart gimp: now the plug-in is shown under the new menu path.
My environment is : win 7 32-bits, gimp 2.8.4.
Please try it! Thanks
 Post subject: Re: error in gimp loader for python plug-ins ?
PostPosted: Tue Feb 19, 2013 5:31 am  (#2)
Can you post the code you are changing please - just the registration block is all that's needed as I want to be sure which method you are using to register the menu path.
Kevin
PostPosted: Tue Feb 19, 2013 5:39 am  (#3)
OK Paynekj, here it is:
.... "<Image>/Additional/Diego/My First Python-Fu", ....
this is the new;
the old was:
.... "<Image>/Additional/MyPyFu/My First Python-Fu", ....
Thanks
PostPosted: Tue Feb 19, 2013 6:27 am  (#4)
In your register() call, try changing
to
"My First Python-Fu"
and then adding the argument
menu= "<Image>/Additional/MyPyFu/"
at the end.
PostPosted: Tue Feb 19, 2013 8:31 am  (#5)
to SaulGoode
tried your suggestion, but:
1 - first of all to make the plug-in be accepted I had to add two initial parameters
(PF_IMAGE, "image", "Input image", None),
(PF_DRAWABLE, "drawable", "Input drawable", None),
which normally are not in because defaulted by the interface
(before adding those two additional parameter the call returned an error saying that four parameters where defined but only two registered)
2 - nothing changed with respect to the menu entry, i.e. I still had to clear .gimp-2.8/pluginrc lines related to the plug-in when trying to change MyPyFu to Diego or viceversa
Sorry, but thanks again for the suggestion
(BTW did your suggestion come from the fact that you did try the same and it works by you? in general I'd like to hear from python plug-in writers about such a trial...)
PostPosted: Tue Feb 19, 2013 8:46 am  (#6)
to SaulGoode
1) You have to declare all the parameters that your plug-in expects... the interface then decides which are implicitly available (active image/layer/drawable/path...), and which warrant an entry in a parameter input dialog. When called non-interactively by another plugin, all parameters should be specified.
2) As far as I can tell, the pluginrc file has a timestamp for each plugin, and if at startup the timestamp of the plugin executable file isn't the same as one in pluginrc, the plugin is run to execute its registration code.
PostPosted: Tue Feb 19, 2013 9:16 am  (#7)
I've just tried it on Windows 7 (64) using GIMP 2.8.2 and it works perfectly. Every time I change the "menu=" entry, GIMP re-starts using the new location.
In view of what Ofnuts points out about the timestamp, you haven't got a setting on your text editor that allows you to keep the last modified time of the file?
Kevin
PostPosted: Tue Feb 19, 2013 1:22 pm  (#8)
to Ofnuts and Paynekj
thanks for your support
1 - about the list of parameters in the registration I understand it's better to define always also image and layer; I didn't do it so far because of many suggestions read here and there though various python - gimp documents which are saying those two are implicitly defined by the interface; OK well
2 - about date modified I do not know about preference set-up in my editor to choose it or not; if the fact that I see in the list of .py files of my folder that there is a column with date and time always updated is a proof that the info is available to gimp, fine, it's there; if that info is translated into a single number in pluginrc like for instance the number at the end of "(plug-in-def "C:\\Users\\User\\.gimp-2.8\\plug-ins in prova\\example2u.py" 1360942972", OK, it changes every time
3 - if you tried and in your system everything works, OK, there must be something in my system; because changing the path is not so frequent (normally only during tests up to the "release" of the plug-in, I can survive with that problem.
So, many thanks again to all of you
PostPosted: Tue Feb 19, 2013 4:10 pm  (#9)
The number 1360942972 is a UNIX timestamp
Using http://www.onlineconversion.com/unix_time.htm I can see the time/date is Fri, 15 Feb 2013 15:42:52 GMT
PostPosted: Tue Feb 19, 2013 7:37 pm  (#10)
Actually the number of seconds since Jan 1st, 1970, 00:00:00 UTC. In a unix shell prompt:
>date -d @1360942972
Fri Feb 15 16:42:52 CET 2013
PostPosted: Wed Feb 20, 2013 12:27 am  (#11)
Well, based on your info I supposed my text editor does something wrong in saving, because the translated date shown is not Feb 19 ...
So I decided to try with a different editor: downloaded and installed Cream (Wim), changed the menu path again and saved; unfortunately when launching gimp I didn't see the change in menu path and looking into gimprc the unix timestamp is still the previous (1360942972); there must be some other reason on my system for this behaviour...
Thanks for your support
PostPosted: Wed Feb 20, 2013 1:50 am  (#12)
Let's clarify a couple of things.
Can you be explicit about the order in which you do things. i.e. do you stop GIMP before editing the pluginrc file (GIMP tends to re-save the ...rc files when it exits)
As you're on Windows 7 I start to wonder if you've got a Windows Virtual Store problem, so what is the full path of your pluginrc file?
Kevin
PostPosted: Wed Feb 20, 2013 3:53 am  (#13)
My sequence is as follows when I want to change the menu path:
1-close gimp, if open
2-change the menu path in the plug-in
3-restart gimp
4-because gimp doesn't reflect the menu change...
5-close gimp
6-edit pluginrc, deleting lines related to the plug-in
7-restart gimp and the change is there!
About the second question, the path of pluginrc (as well as of others ..rc)is the following:
C:/Users/User/.gimp-2.8 (User is the name of myself, with administrator rights)
Thanks for your support Kevin
