It just popped out a topic on concentric circle
viewtopic.php?f=9&t=4499&start=10 and it give me a idea for a very interesting animated effect
First use , no kidding here , could be to create looping animation to help enter in state of self hypnosis or trance
Basically the script should
(EDIT; maybe i explained better below if you found confusing , skip to the part in italic and blue )
1 ) create a image filled by concentric circles thickness and quantity should be user choice, default colours black on white, but any other couple of contrasting colours (red & green,yellow and violet..) may be chosen
This image must be bigger then final desired size2) duplicate the layer
3) Default colour is black & white default layer mode for the dup on top is darken only:
4) According to the RADIUS chosen by the user the top layer is off setted
BUT along a very strict spiralyou may have a poor idea of the effect by the 2 frames in the bottom message here
viewtopic.php?f=9&t=4499 BUT animated effect is much more mesmerizing
5) When reached the max radius, then may start the inverted movement to create a ping pong loop
6) Everything should be crop , to cut out all not_overlapping area at the border
About colours and merging modes Black& White and Darken only will always give good results, but many other combinations are worth exploring
i hope i was clear ...maybe i did summarize better here the script should
1 ) Create 1 image with 2 layers of same size filled with same pattern of concentric circles :example colors Black & White and top layer in to Darken Only mode
2 ) at beginning the layers are perfectly aligned then the top layer start to offset spiralling away for the given range
3) the visible of each of this combinations of the 2 layers is saved as new layer in a new image ,in this new image the periphery where the 2 layers didn't overlap should be crop away
4) allow to loop back
5) Change layer mode to Lighten Only , will be no difference for the first frame of the new loop, where the identical layers are perfectly aligned but only when will start to offset ...
a similar script would make very mesmerising animations
