It is currently Tue Nov 24, 2026 3:10 am
Post new topic Reply to topic  [ 83 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Fur script REL 4
PostPosted: Thu Mar 14, 2013 10:21 pm  (#1)
The fur in this script is created using gimpressionist, a number of settings are incldeded to help you get the result you are looking for.
The menu's can be found under Script-Fu/Alpha-to-Logo/Fur and Script-Fu/Logos/Fur
images below are done with default settings
(I might enter my bear in great-grand-daughters pre-skool competition) :rofl
; Rel 0.02 - Changed text in gimpressionist to "Furry" instead of "furry"
; Rel 0.03 - Added option to use the existing colors and a softness setting
; Rel 0.03.3 - bugfix
; Rel 0.04 - improved the output image appearance
download the REL 4 script below↓
Fur.scm [11.58 KiB]
Downloaded 351 times
 Post subject: Re: Fur script
PostPosted: Thu Mar 14, 2013 10:37 pm  (#2)
Where's the script? :)
PostPosted: Thu Mar 14, 2013 10:51 pm  (#3)
sorry everyone I forgot to add the script :oops:
PostPosted: Thu Mar 14, 2013 11:42 pm  (#4)
Thanks Graechan. 2 passes of the Script-fu second result on top set to lighten followed by G'MIC anisotrophic (fake smudge) and an Enhance Detail Script-fu. :)
PostPosted: Thu Mar 14, 2013 11:50 pm  (#5)
Well dang. Got these two error messages.
PostPosted: Thu Mar 14, 2013 11:59 pm  (#6)
do you have the preset Furry in your share\gimp\2.0\gimpressionist\Presets folder or your pref_1\gimpressionist\Presets folder
It is a default gimpressionist preset so I did not post it
PostPosted: Fri Mar 15, 2013 1:09 am  (#7)
Yes, there is a preset named Furry in my Gimpressionist folder.
PostPosted: Fri Mar 15, 2013 1:20 am  (#8)
For the call to gimpressionist to fail, I can not think of any other reason as it functions without fail in Windoze 7 gimp 2.8.2 and whatever Lyle is using,
I hope its not a Linux problem :geeking
PostPosted: Fri Mar 15, 2013 1:22 am  (#9)
The "furry" in the script is all lowercase, the "Furry" in the folder on my machine is capitalized. Could that make a difference?
PostPosted: Fri Mar 15, 2013 1:25 am  (#10)
(no muppets were harmed in the making of this text)
PostPosted: Fri Mar 15, 2013 1:34 am  (#11)
In mine it's Furry in the folder and furry in the script so I do not think that Matters
PostPosted: Fri Mar 15, 2013 2:56 am  (#12)
'O' will the gimpressionist preset 'Furry' work on an open Image in your gimp
PostPosted: Fri Mar 15, 2013 3:42 am  (#13)
Script works great on cartoon images and is great fun
used Multi-fill script (and image) from RobA to exclude or include certain areas
PostPosted: Fri Mar 15, 2013 4:05 am  (#14)
Must be a Linux thang cuz mine doesn't work either.
PostPosted: Fri Mar 15, 2013 4:19 am  (#15)
Thanks a bunch for the script, Graechan!
Will give it a go this weekend.
PostPosted: Fri Mar 15, 2013 7:11 am  (#16)
Thank you for another gem Graechan.
PostPosted: Fri Mar 15, 2013 9:46 am  (#17)
Bonjour,
@Graechan
replace
(plug-in-gimpressionist 1 image fur-layer "furry")
by
(plug-in-gimpressionist 1 image fur-layer "Furry")
tested on OpenSUSE (case sensitive)
PostPosted: Fri Mar 15, 2013 5:14 pm  (#18)
samj wrote:
Bonjour,
@Graechan
replace
by
Samj no problems to change but may I ask what is 'OpenSUSE'
 Post subject: Re: Fur script Rel2 'Linux mod'
PostPosted: Fri Mar 15, 2013 6:09 pm  (#19)
Just updated script in hope of it helping with Linux users
PostPosted: Fri Mar 15, 2013 6:21 pm  (#20)
ok thanks Graechan. I will give it a try.
