It is currently Mon Aug 17, 2026 2:10 am
 Post subject: Script 8 Colors (experimental)
PostPosted: Wed Apr 03, 2013 4:28 pm  (#1)
Bonjour,
Here is a small script on the colors. This is experimental.
Colors > 8 Couleurs ...
Image 1 By Floyd's Noise http://www.flickr.com/photos/floyd_nois ... otostream/
License CC BY-NC-SA 2.0
8_couleurs.zip [2.85 KiB]
Downloaded 172 times
 Post subject: Re: Script 8 Colors (experimental)
PostPosted: Wed Apr 03, 2013 6:09 pm  (#2)
Interesting script, samj!
I used an (rgb) picture of black and white piano keys with, the only noticeable color, a thin red line along the top of the keys. All the 8-color script settings were default. In the new image I hid the black layer and duplicated the 8-colors layer. Duplicate layer was set to Saturation, original to Dodge both 100% opacity.
Image URI: http://mrg.bz/LJhRR9
PostPosted: Wed Apr 03, 2013 6:38 pm  (#3)
Bonne nuit Samj:
I was playing a bit with the script.
I set the output layers as follow:
calque_8_couleurs → grain merge & 50 % opacity
calque fond → color & 30 % opacity
after I created a New from visible layer, and I've applied Unsharped mask (default values, I think).
Finishing, Hue and saturation:
Hue: - 9
Luminosity: - 6
Saturation: - 34
PostPosted: Wed Apr 03, 2013 6:46 pm  (#4)
Bonsoir,
:tyspin Jamac4k
playing with colors : Image 2 : http://www.fontplay.com/freephotos/4thf ... 706-13.jpg
License : http://www.fontplay.com/freephotos/
PostPosted: Wed Apr 03, 2013 6:53 pm  (#5)
very nice result, jamac4k !
PostPosted: Thu Apr 04, 2013 9:29 am  (#6)
Here is a test, an image created using this script-fu.
PostPosted: Fri Apr 05, 2013 6:50 am  (#7)
...but that looks terrific...
PostPosted: Fri Apr 05, 2013 8:45 am  (#8)
For the texture there is a tutorial of 2000-2001 :
http://gug.criticalhit.dk/tutorials/ronq1/
You can apply on the image or create a pattern.
This should work on almost all images using the default script-fu parameters.
PostPosted: Fri Apr 05, 2013 4:01 pm  (#9)
# Esper:
Thanks, I'm glad you like the effect.
# Samj:
Bonsoir,
Could the script had the option to choose a color first and then develop the tones.
I tested with a nude model on black background with blues and I liked the results enough.
This is because I'm a little crazy with the Dave Hill and Jill Greenberg's effects and want to find a method that does not involve brushwork to the idea that anyone can create a script or plug-in.
PostPosted: Fri Apr 05, 2013 5:20 pm  (#10)
@Jamac4k
I'll make another script that save 8 selections converted to paths. The user can do what he wants with these paths:
- Draw paths
- Re-converted into selections and fill colors, patterns.
I will write the script-fu tomorrow.
PostPosted: Fri Apr 05, 2013 6:44 pm  (#11)
@Jamac4k
The script is created (save 8 selections converted to paths).
Select > 8 Selections To Paths ...
8_selections_to_paths.zip [2.62 KiB]
Downloaded 74 times
PostPosted: Sat Apr 06, 2013 5:49 am  (#12)
The result is nice :paint
I'll definitely modify the script on the selections :
- Store the selections and paths.
- Choose an option "Soften" for each path.
- Set the pre-treatments.
- Choose the number of selections (1 to 8)
I will make another topic for the new script.
