It is currently Wed Aug 19, 2026 6:40 pm
 Post subject: a scale multiple layers script
PostPosted: Thu Apr 18, 2013 7:13 pm  (#1)
I need a script to scale multiple layers to the same size all at once.
I thought i saw one here before but using search i could not locate it.
Does anyone know how to write one to do this or is there one out there i missed?
Thanks folks.
 Post subject: Re: a scale multiple layers script
PostPosted: Thu Apr 18, 2013 7:49 pm  (#2)
If the layers are chained and you use the scale tool, they will be scaled together.
Yet another "tell me hat you need, and I'll show you how to do without it" :)
PostPosted: Thu Apr 18, 2013 8:51 pm  (#3)
Rod you could try this
Menu location layer/Scale Linked Layers
Scale Linked Layers.scm [2.12 KiB]
Downloaded 347 times
PostPosted: Thu Apr 18, 2013 10:34 pm  (#4)
Sweet! You even added scale from center.
Thanks Graechan. :)
Ofnuts thanks for the information on scaling linked layers.I learn something new in Gimp every day. :bigthup
PostPosted: Thu Apr 18, 2013 10:51 pm  (#5)
Rod I made a mistake that I did not notice until after I posted I spelled RGB* RBG* in the menu if your copy has this error you can re download or fix
(script-fu-register "script-fu-scale-linked-layers"
"Scale Linked Layers"
"Will Scale Linked Layers"
"Graechan"
"Graechan - http://gimpchat.com"
"April 2013"
"RGB* GRAY* INDEXED*"
PostPosted: Thu Apr 18, 2013 10:55 pm  (#6)
"Graechan"
"April 2013"
Thanks for letting me know Graechan.I ran the script on a RGB image before fixing and it ran fine. :bigthup
Awesome script and it will be very handy.
PostPosted: Thu Apr 18, 2013 11:34 pm  (#7)
onuts suggestion to just link the layers and scale did not work in my gimp, as only the active layer was scaled?
maybe I did it wrong but I don't think everything done on a linked layer transfers to the other linked layers
PostPosted: Fri Apr 19, 2013 12:40 am  (#8)
I tried it in Gimp-2.8.4 (Parthas install) and it worked for me. :)
I made one layer, duplicated it 4 times and linked 4 layers and scaled proportionately and it scaled all the linked layers.I love the script you wrote better though Graechan as it scales from center. :bigthup
I don't know why Gimp doesn't have this setting default already. :)
PostPosted: Fri Apr 19, 2013 1:37 am  (#9)
This actually applies to all geometric transforms (rotate/scale/shear/perspective/flip...) and applies to channels and paths that are linked as well... (so you can keep a layer, a channel, and a path in sync...).
PostPosted: Fri Apr 19, 2013 1:56 am  (#10)
Strangly it only worked with the scale tool but not with the scale-layer plugin in 2.8 2 and 2.8.4 windows
PostPosted: Sat Apr 20, 2013 7:40 pm  (#11)
I am thinking it must be your version Graechan as it worked for me in Parthas version.
PostPosted: Tue Sep 15, 2015 5:19 pm  (#12)
The attachment Scale Linked Layers.scm is no longer available
Is there a way to remove the Linked part of this? I am working with about 2000 layers and I dont want to have to link each and every layer individually since that is tedious....
Before I finished typing this I looked at the code and figured out I just had to remove an if conditional to accomplish this I shall share the modified file (hopefully the credit change I made is appropriate if not let me know).
EDIT: I found a bug that I need help fixing since I am not familiar with the syntax of script-fu (im really only familiar with c++ and java so I was able to figure out the above but not much else). I was scaling all of the layers up to 2000 px by 1 px and the one layer that already had that width messed up and increased to 3000 px by 1 px instead of being skipped since it was already the correct size. I assume I just need to add an if conditional into the while loop that says "if (get-width = new-width) then (if (get-height != new-height) then (scale-to-new-height)) else (if (get-height != new-height) then (scale-to-new-height-and-new-width) else (scale-to-new-width). Thanks for any help
Scale Layers.scm [2.11 KiB]
Downloaded 101 times
PostPosted: Tue Sep 15, 2015 5:23 pm  (#13)
You can try holding down shift key and click the link to turn them all on or off.
TinT
