It is currently Thu Aug 13, 2026 11:40 pm
 Post subject: Binaries Repeated Painter - Linux Windows 32-64bits
PostPosted: Wed Apr 24, 2013 10:03 am  (#1)
By Tibor Bamhor
Filters > Artistic > Periodic Painter
PURPOSE:
It is tu simplify creation of seamles tiles/ patterns. Anything you paint is periodically copied.
So you can see your image/patterns how it looks in a real-time.
USE:
Create an empty image
Paint something small and hit "spread changes"
Repeat
periodicpaint-0.1.1_32bits-64bits-Linux-Win_Gimp-2.8.zip [2.99 MiB]
Downloaded 610 times
 Post subject: Re: Binaries Repeated Painter - Linux Windows 32-64bits
PostPosted: Wed Apr 24, 2013 10:05 am  (#2)
Sam you rock! :bigthup
Thanks.
I am still stumbling along trying to get my environment working. :(
PostPosted: Wed Apr 24, 2013 10:11 am  (#3)
Awesome tool!
PostPosted: Wed Apr 24, 2013 1:23 pm  (#4)
it goes to:
c:\users\#your name#\.gimp-2.8\plugins
PostPosted: Wed Apr 24, 2013 1:25 pm  (#5)
Thanks.
Where's the problem?
PostPosted: Wed Apr 24, 2013 1:50 pm  (#6)
Thanks.
Hey Onkel good to see you again. :)
The problem is while compiling GEGL i get an intool error.
Here is the error
checking for BABL... yes
checking for pkg-config... (cached) /usr/gtk/bin/pkg-config
checking pkg-config is at least version 0.16... yes
checking for GLIB - version >= 2.28.0... yes (version 2.28.8)
checking for DEP... yes
checking for bind_textdomain_codeset... yes
checking whether NLS is requested... yes
./configure: line 17693: intltool-update: command not found
checking for intltool >= 0.40.1...  found
configure: error: Your intltool is too old.  You need intltool 0.40.1 or later.
Here is my command line
./configure --prefix=/opt/gimp-2.8.4 CPPFLAGS="-I/usr/include -I/c/Python27/include" LIBS="-L/usr/lib -L/c/Python27/Lib" --disable-docs
I have this version of intltool installed in opt/lib and as you can see the compiler did find it but it still wants me to update.
First time i ever ran into this problem compiling GEGL.Any help would be appreciated.
Here i go again. :rofl
PostPosted: Wed Jul 17, 2013 8:17 am  (#7)
Bonjour,
Update binaries - Version 0.2.0
By Tibor Bamhor
periodicpaint-0.2.032bits-64bits-Linux-Win_Gimp-2.8.zip [2.57 MiB]
Downloaded 304 times
PostPosted: Wed Jul 17, 2013 11:31 am  (#8)
Thank you for the update Sam. :)
PostPosted: Wed Jul 17, 2013 2:19 pm  (#9)
Thanks samj. :)
