It is currently Fri Aug 21, 2026 1:58 am
 Post subject: Chris-Toast Photofont done
PostPosted: Wed May 08, 2013 12:45 am  (#1)
The file is set at 1000 pixel resolution :lol Which means you can actually make each letter 1000x1000 pixels if you wish inside PhotoFont-Start.
It weighs about 64MB.I am uploading now. :bigthup
Image examples
1000 pixel res for the letter A.
A couple letters did confuse me but you can test them all and i can remake them if need be. :bigthup
As i said it is finished.Just download from here.
Sorry this download is temporarily unavailable.
Chris-Toast PhotoFont
 Post subject: Re: Chris-Toast Photofont done
PostPosted: Wed May 08, 2013 1:09 am  (#2)
These aren't Chris's but they are coming soon also. :hehe
These came from someone PC ran across online.I can not for the life of me remember his name but if he reads this and PM's me i will give him his credit due.I have to give credit also to PC for finding the graphics. :bigthup
I have the PHF files pretty much ready, and they will be available soon. :bigthup
PostPosted: Wed May 08, 2013 2:59 am  (#3)
Rod this looks good but you forgot to copy the upper case into the lower case, it has left the lower case blank
I'm looking forward to more sets
PostPosted: Wed May 08, 2013 3:09 am  (#4)
No i copied the upper into the lower.Using shift + letter should give you caps and just pressing the letter will give you caps.There are no small letters with this font.Chris didn't make it that way.
Sorry.
PostPosted: Wed May 08, 2013 6:33 am  (#5)
Um ... and so what is a picture font? Apparently unusable for me. I downloaded the file, looked inside and froze my machine by double-clicking the contents.
Why would I want a picture font? Seems like I can make my own font fills using a regular font and a pattern.
PostPosted: Wed May 08, 2013 11:17 am  (#6)
rod: thanks, that must have taken a lot of time! i loved the steampunk letters, looking forward to those.
 Post subject: Re: Chris-Toast Photofont done for Windows and Mac systems
PostPosted: Wed May 08, 2013 11:31 am  (#7)
O this runs with the Photofont Start Adobe plugin and PSPI.OR you can use the PHF file i created to load the images for you and not have them embedded.Of course that means you will only be able to use font images you create.
You would need to install pspi and the plugin or XnView or a similar program that runs adobe plugins and run the Photofont Start filter through that.Of course there is also Shellout.py.Thank you Rob!
Then just open the plugin from your favorite program and select install photofont.Browse to the PHF file you downloaded (Chris-Toast.phf), and click it.Photofont start will load it in and you will never have to load it again.It will stay installed.
On my machine selecting the PHF from the drop down list took several seconds.This is the largest one i have created yet so others will be probably smaller in the future.
Hope that explains everything O.I fixed the topic for others to know this is for Windows or Mac.Though the one i created that LOADS images is available and should work on any system.Don't quote me on that though.
Sorry for my not explaining that better before.
You can get more info here.- viewtopic.php?f=9&t=3827&hilit=PHF
Here are some free PHF files you can dl also. - http://www.photofont.com/photofont/get/free/
Again sorry for the confusion everyone. :)
PostPosted: Wed May 08, 2013 7:35 pm  (#8)
'O' photo fonts are fantastic to play with and easy to create, here are some that I have collected
PostPosted: Sun Jun 08, 2014 11:02 am  (#9)
Hi, The three Steampunk Fonts you have listed in this post are by Georgie Retzer of Austria. You'll find him on Deviantart.... this site won't let me post a link. He's also on facebook. Calls himself Illustratorg
PostPosted: Sun Jun 08, 2014 2:18 pm  (#10)
Very sexy Graechan
PostPosted: Sun Jun 08, 2014 3:52 pm  (#11)
You have to have 5 posts in order to start posting links. :)
PostPosted: Sun Jun 08, 2014 3:52 pm  (#12)
The link to the plugin doesn't work. Where can users obtain this plugin?
PostPosted: Thu Jun 12, 2014 3:45 am  (#13)
Fontlab does not seem to be hosting the photofont start plugin anymore.
You need to download it from somewhere else.
like http://photofont-start.software.informer.com/2.0/
PostPosted: Thu Jun 12, 2014 9:17 am  (#14)
How to convert image file types (*. png) for format * phf?
Which program is best for this purpose?
PostPosted: Thu Jun 12, 2014 6:04 pm  (#15)
ok
I have PSPI and photofont installed but I can't find them to open the toast font
PostPosted: Thu Jun 12, 2014 6:09 pm  (#16)
As far as i know there is only one way other than VERY expensive font software and that is with the Photofont PHF file i wrote and i believe you already have this. :)
You can find that here. http://www.gimpchat.com/viewtopic.php?f=9&t=3827
pirate541 you need to open Filters>Fontlab>Photofont Start and click the install photofonts button. Browse to the PHF file and select it. Photofont will install it for you.
PostPosted: Thu Jun 12, 2014 6:12 pm  (#17)
Rod
That's the thing
I can't find it under filters
PostPosted: Thu Jun 12, 2014 6:23 pm  (#18)
pirate541 wrote:
Rod
That's the thing
Did you add a path to the 8BF binary using Filters>Photoshop Plugins Settings yet?
PostPosted: Thu Jun 12, 2014 6:31 pm  (#19)
Looks at you,totally confused :roll: :roll: :roll:
PostPosted: Fri Jun 13, 2014 2:29 am  (#20)
Nice looking "Steampunk" fonts. :bigthup
