It is currently Thu Sep 24, 2026 3:47 am
 Post subject: Script Writing Resources For GIMP
PostPosted: Tue Nov 16, 2010 10:30 pm  (#1)
Script-Fu Tutorial
http://www.seul.org/~grumbel/gimp/scrip ... u-tut.html
Getting Started
http://gimpbook.com/scripting/
Tiny-Fu
http://www.ve3syb.ca/software/gimp/tiny-fu.html
Basic Scheme
http://www.gimp.org/tutorials/Basic_Scheme/
Scheme Programming Language Documentation
http://schemers.org/Documents/Standards/R5RS/HTML/
http://people.csail.mit.edu/jaffer/r5rs_toc.html (alternate link)
Script-Fu Updates in GIMP (2.4)
http://www.gimp.org/docs/script-fu-update.html
Writing a GIMP Plug-in
http://www.gimp.org/docs/plug-in/plug-in.html
Python Tutorial
http://docs.python.org/tutorial/index.html
Python Language Reference
http://docs.python.org/reference/index.html
GIMP Python Documentation
http://python-fu.sourceforge.net/docs.html
Extending Gimp with Python: Python-Fu plug-ins (parts 1 & 2)
http://www.exp-media.com/node/18
http://www.exp-media.com/content/extend ... ins-part-2
Fencepost's Script Writing Tutorials
GIMP Scripting 101
GIMP Scripting 102A
GIMP Scripting 102B
GIMP Scripting 103A
GIMP Scripting 103B
Teach Yourself Scheme:
http://www.ccs.neu.edu/home/dorai/t-y-s ... Z-H-1.html
 Post subject: Re: GIMP Script Writing Resources
PostPosted: Wed Nov 17, 2010 4:33 am  (#2)
More scheme resources that I've found useful:
http://www.scheme.com/tspl3/
http://www.cs.indiana.edu/scheme-repository/imp/siod.html
Kevin
PostPosted: Wed Nov 17, 2010 12:32 pm  (#3)
And the official docs:
http://docs.gimp.org/en/gimp-using-scri ... orial.html
-Rob A>
PostPosted: Fri Dec 07, 2012 4:33 pm  (#4)
An excellent resource from Akkana Peck (one of the GIMP developers) on creating scripts and plugins for GIMP:
PostPosted: Tue Jan 08, 2013 3:39 pm  (#5)
It is also worth mentioning the "Portable Python" project for Windows, which provides a standalone implementation of the Python interpreter along with additional libraries and several useful applications:
http://www.portablepython.com/
 Post subject: Re: Script Writing Resources For GIMP
PostPosted: Thu Nov 06, 2014 6:57 am  (#6)
Monsoonami's script course needs mentioning here also. Excellent beginner course.
https://www.youtube.com/watch?v=dAuJJ6P8Jxs
PostPosted: Tue Jul 21, 2015 11:39 am  (#7)
For the script language Python the info after James Henstridge (http://www.gimp.org/docs/python/) is scattered, here some more.
An article about using Python for GIMP and 'PyDev' plug-in for the 'Eclipse' IDE, written by Nathan A. Good (2011).
http://www.ibm.com/developerworks/library/os-autogimp/
Also for debugging 'pygimp' plug-in by 'ofnuts', a member here, see http://gimpforums.com/thread-debugging-python-fu-scripts .
Edit: sorry for the above, this is not the address any more (2016/11/25)!
For some of your 'pygimp' info, open the GIMP python-fu console and enter 'help(gimp)' and save.
PostPosted: Sun Nov 29, 2015 2:51 pm  (#8)
http://www.gnu.org/software/mit-scheme/ ... me-ref.pdf
PostPosted: Tue Oct 08, 2019 3:20 am  (#9)
Two problems:
1. I would likt to open a new post to ask what I have to ask in 2.
2. VERRY very strange experience! Macbook Gimp 2.10 Emacs
I got out of an (old) backup my change of Arakne huidlab:
guidlabextra.py
I copied it into /Users/peterkhgragert/Library/Application Support/GIMP/2.10/plug-ins:
And big surprise I got the plugin back and running as expected.
Trying to us Gtk for other things was horrible unsuccessful
The real info seams to be in on dir higher
in pluginrc, there I found it noted. OK so far.
I made copies (with Emacs) to a newly created directory in */2.10
removed all from pluginrc and plug-ins about guideslabextra
and indeed plugin not anymore in a new started GIMP
putting the guidelabextra.py back into plug-ins ==> NO Success starting Gimp again (new).
Now remembering it earlier I saw guideslabextra.py~ shortly in the
startup image of GIMP.
So copying back guideslabextra.py~ to plug-ins.
The plugin works again .
Totally not understood.
And the first try I had only guideslab.py in plug-ins
(not knowing how I got the *.py~ , which seems to be essential to
become really active.
HELP HELP
Move this please to a new post and let me know where, please.
Peter
PostPosted: Tue Oct 08, 2019 4:57 am  (#10)
Files ending with "~" are backup copies automatically created by some editors (such as Emacs). IMHO you likely unwillingly edited guideslabextra.py and made changes that are considered a syntax error by Python (Python is very picky about line indentation, a tab or 8 space is not the same indentation, so editing a Python file is fraught with peril if you (or your editor) don't use the same convention as the other author (spaces or tabs). OTOH the backup guideslabextra.py~ is still the original code and works.
