It is currently Mon Aug 17, 2026 7:23 pm
 Post subject: New Script-Fu : "Spirograph_for_beginners.scm" V-2
PostPosted: Sun May 19, 2013 8:33 am  (#1)
Bonjour,
Paths can be saved in SVG format.
The script-fu is in the archive "Spirograph_for_beginners_Version2.zip".
File > Create > Patterns > Spirograph for beginners ...
This script is an adaptation of "Epicycloid_for_beginners.scm" ( viewtopic.php?f=12&t=7276#p92776 ).
Edit 20130520
Version 2
This script is modified to create a small path "Path_Inbetweener" to use "path inbetweener" created by Ofnuts.
site : http://gimp-path-tools.sourceforge.net/ ... nbetweener
download : http://sourceforge.net/projects/gimp-pa ... y/download
Spirograph_for_beginners_Version2.zip [3.53 KiB]
Downloaded 162 times
 Post subject: Re: New Script-Fu : "Spirograph_for_beginners.scm"
PostPosted: Sun May 19, 2013 9:18 am  (#2)
That would make a fine plate to eat off of Samj. :)
PostPosted: Sun May 19, 2013 10:21 am  (#3)
for SamJ
my first play
PostPosted: Sun May 19, 2013 11:02 am  (#4)
Thanks samj! I don't know quite what I'm doing with it, but it's sure fun.
PostPosted: Sun May 19, 2013 12:03 pm  (#5)
ooooh, for beginner, I will grab this one. I like script fu only because I know where to put it. Everytime I try to put in a py, it never shows up for me.
PostPosted: Mon May 20, 2013 1:22 am  (#6)
:tyspin , I love the designs and the effect of stained glass.
The script-fu is modified to create a small path "Path_Inbetweener" to use "path inbetweener" created by Ofnuts.
The new script-fu is in the archive "Spirograph_for_beginners_Version2.zip".
Here is an example created with version 2 of the script-fu that uses "path inbetweener"
PostPosted: Mon May 20, 2013 5:23 am  (#7)
Sam you are awesome! :)
PostPosted: Mon May 20, 2013 5:31 am  (#8)
Then stroked, merged with a white layer and blurred.Then color balance. :)
Super cool effect with Levels and then curves.
Thank you Sam! :bigthup
PostPosted: Mon May 20, 2013 8:14 am  (#9)
It is possible to create Epicycloids and Hypocycloids with this script-fu.
Use a very small coefficient value for the frequency. Example KF = 3.5
To create an Epicycloid :
Frequency 1 = 10
Frequency 2 = Frequency 1 * KF = 10 * 3.5 = 35
Radius 2 = 50
Radius 1 = KF * Radius 2 = 3.5*50 = 175
To create a Hypocycloid :
Frequency 1 = 10
Frequency 2 = Frequency 1 * KF * -1 = 10 * 3.5 * -1 = -35
Radius 2 = 50
This script is now very, very slow. Enough time to quietly drinking coffee :rofl
PostPosted: Mon May 20, 2013 8:36 am  (#10)
Another example to illustrate the previous message :
PostPosted: Mon May 20, 2013 4:55 pm  (#11)
Examples of values ​​for flowers :
