It is currently Sun Aug 16, 2026 3:23 pm
 Post subject: New Script-Fu "Pursuit_Curve.scm"
PostPosted: Sat May 25, 2013 7:16 am  (#1)
Bonjour,
File > Create > Patterns > Pursuit Curve ...
Each polygon is saved as a path.
The script-fu "Pursuit_Curve.scm" is in the archive "Pursuit_Curve_Version-3.zip".
Edit 20130527 : Version 5 - More options for filling polygons.
Edit 20130527 : Version 4 - New option : Fill polygons gray / Remplir polygones de gris
Edit 20130526 : Version 3 - Ajouts : Types B , C , Inversion A , Inversion C | Tangency / Tangence
Edit 20130525 : Version 2 - Changes on the advice of Saulgoode and add "Variation forme polygone".
Pursuit_Curve-Version-5.zip [4.96 KiB]
Downloaded 172 times
 Post subject: Re: New Script-Fu "Pursuit_Curve.scm"
PostPosted: Sat May 25, 2013 7:20 am  (#2)
That looks really cool samj. Are your scripts only for 2.8 or will they work in 2.6?
PostPosted: Sat May 25, 2013 7:20 am  (#3)
samj: :wow thanks, samj! this one looks really fun!
PostPosted: Sat May 25, 2013 7:40 am  (#4)
If I might offer a couple of suggestions, though nothing of critical importance.
When you are creating a new image, I'd recommend using 'gimp-undo-disable/enable' rather than 'gimp-undo-group-start/end'. There is never any need to undo things with a brand new image; it just takes you back to a completely useless, empty image. The individual steps in an undo group also use up steps/memory allocated to the undo history, potentially causing GIMP to forget undo steps from other images that are open.
Also, 'gimp-context-push' should save all of the settings that you are currently storing in temporary variables (e.g., 'old_context-antialias'). All of the original settings can then be restored with a single call to 'gimp-context-pop'.
Finally, you might consider using 'script-fu-menu-register' instead of specifying the menu path in 'script-fu-register' (a methodology which has been deprecated).
For example, instead of:
(script-fu-register "Pursuit_Curve_samj"
                    _"<Image>/File/Create/Patterns/Pursuit Curve ..."
use:
                    _"Pursuit Curve ..."
(script-fu-menu-register "Pursuit_Curve_samj"
                    _"<Image>/File/Create/Patterns"
PostPosted: Sat May 25, 2013 7:46 am  (#5)
:tyspin AnMal, Saulgoode
@Erisian
This script is for Gimp 2.8
PostPosted: Sat May 25, 2013 7:55 am  (#6)
thanks, SamJ!
My first play..
PostPosted: Sat May 25, 2013 8:59 am  (#7)
:bigthup Dinasset
Changes in the script-fu Version 2 on the advice of Saulgoode and add "Variation forme polygone".
The script-fu is in the archive "Pursuit_Curve_Version-2.zip"
PostPosted: Sat May 25, 2013 5:52 pm  (#8)
Another great path script Sam. :)
Thanks.
PostPosted: Sat May 25, 2013 6:44 pm  (#9)
dinasset: great results! i've only got as far as installing it yet, but i'll be back...
PostPosted: Sun May 26, 2013 12:03 pm  (#10)
:tyspin All
Version 3 now available :
+ Types B , C , Inversion A , Inversion C
+ Tangency / Tangence
PostPosted: Mon May 27, 2013 5:28 am  (#11)
Bonjour,
New version 4 : New option "Fill polygons gray / Remplir polygones de gris".
PostPosted: Mon May 27, 2013 5:44 am  (#12)
Looks really good samj. Thank you again.
PostPosted: Mon May 27, 2013 6:40 am  (#13)
Took me awhile to find the location - finally figured out why I couldn't find it. Hadn't restarted my gimp. (oops). Then I had another while to work it out but finally came up with this. Haven't tried adding colours yet.
PostPosted: Mon May 27, 2013 6:52 am  (#14)
Last one for the night - to get it in my brain how it works ;) Thanks again Samj
PostPosted: Mon May 27, 2013 7:33 pm  (#15)
looks almost like a spider web in the sunlight!
PostPosted: Mon May 27, 2013 7:52 pm  (#16)
Hi Sallyanne,
Just a hint, if you copy new '.scm' scripts into your gimp, you only need to 'refresh' the scripts rather than exit and re-start gimp. :)
Use Filters->Script-Fu->Refresh Scripts
PostPosted: Mon May 27, 2013 11:17 pm  (#17)
Thanks FB, will have to remember that.
PostPosted: Mon May 27, 2013 11:27 pm  (#18)
sallyanne: nice job on those! i really like the one where you added the supernova.
PostPosted: Tue May 28, 2013 1:45 am  (#19)
Two more
After colouring this with two gradients I added a flower to the centre and then a 6 sided polygon to the centre of that.
Coloured the same then added a swirl on top.
PostPosted: Tue May 28, 2013 2:07 am  (#20)
Wow, Sallyanne. That top one really has depth.
When I stare at the center, it starts moving and I feel like I've been hip-mo-tized. :shock:
