It is currently Sat Aug 29, 2026 11:35 am
Post new topic Reply to topic  [ 172 posts ]  Go to page 1, 2, 3, 4, 5 ... 9  Next
 Post subject: Pencil Shade script Rel8 [for 2.10 & gmic-qt made faster for wisps]
PostPosted: Sun Jul 07, 2013 8:48 pm  (#1)
Creates a pencil drawing using a shaded style using a convolution Matrix and Difference of Gaussians plugins
Note! from Rel5 Now with additional Wisps script [GMIC] required
Wisps output example 'The Ghost Train' (works best on cluttered images)
Original Image 'Pencil Shade'
Output Image
Menu Location is Filters/Artistic/Pencil Shade
Menu Location is Script-Fu/Effects/Wisps
; Rel 0.02 - additional settings added and refined to use current PDB CALLS FOR 2.6 AND 2.8
; Rel 0.03 - Bugfix to remove final depreciated procedures
; Rel 0.04 - Bugfix to fix Typo 'oops!'
; Rel 0.05 - Added 'Wisps Script' [Thanks to GnuTux]
; Rel 0.06 - Updated 'Wisps' to include changes to Gmic Dreamsmooth filter
; Rel 0.07 - updated for 2.10 and Gmic_qt
; Rel 0.08↓ - Added Script Speed Widget for Wisps
File comment: Pencil Shade & Wisps Rel8
for 2.10 & gmic-qt
Pencil-Shade.scm [14.07 KiB]
Downloaded 226 times
 Post subject: Re: Pencil Shade script
PostPosted: Sun Jul 07, 2013 8:58 pm  (#2)
Cool
PostPosted: Sun Jul 07, 2013 9:18 pm  (#3)
PhotoComix you asked about the convolution matrix so I thought I'd explore It's use in a couple of scripts
below It's used to provide shading or shadow to an Image
PostPosted: Sun Jul 07, 2013 10:27 pm  (#4)
COOL ...now here is 5 AM and still i have to go to sleep but i will try tomorrow
PostPosted: Mon Jul 08, 2013 3:49 am  (#5)
graechan: this looks fun!
PostPosted: Mon Jul 08, 2013 11:02 am  (#6)
WOW! Another gem from Graechan! Thank you.
PostPosted: Mon Jul 08, 2013 12:10 pm  (#7)
Check this out Graechan
I ran the script with defaults but changed it around a bit.
I dropped the Line layer below the Shade layer and set both to 100 opacity.
The line layer is set to grain merge and the shade layer is on color mode.
The original image is kept on the bottom.
Here are the results with defaults before i changed the layers around.
Just thought i would let you know. You may want to switch the layers around (line and Shade).
Of course switching the two layers and their modes and opacity made for better results also (without the original).
The opacity had to be much lower for the top (Shade), layer though.
Just a suggestion. :)
PostPosted: Mon Jul 08, 2013 12:25 pm  (#8)
You know this may make a great bg remover Graechan? Look at the detail in the hair. :)
PostPosted: Mon Jul 08, 2013 6:52 pm  (#9)
Thanks for exploring the script a bit Rod and I noticed how well it distinguished f/g from b/g
 Post subject: Re: Pencil Shade script Rel2[added settings and refined for 2.6 2.8]
PostPosted: Tue Jul 09, 2013 11:14 pm  (#10)
Updated to Rel 2 see initial post
PostPosted: Wed Jul 10, 2013 12:20 am  (#11)
Here are some results from the script
PostPosted: Wed Jul 10, 2013 5:08 am  (#12)
I really like that effect Graechan. thanks for sharing.
PostPosted: Wed Jul 10, 2013 7:10 am  (#13)
Nice one. Graechan. I like the way you handled the 2.8 & 2.8 support. :hehe
Here are my results, using a pic I took of New York New York from my car window in Vegas.
On this one. I kept the layers, used difference mode, colorized, then smoothed.
PostPosted: Wed Jul 10, 2013 8:06 am  (#14)
Those are very cool Tux. I love the black and white one best.
PostPosted: Wed Jul 10, 2013 8:40 am  (#15)
Thank you Graechan. :)
Tux those are really great.
PostPosted: Wed Jul 10, 2013 10:17 am  (#16)
Not downloaded rel 2 yet.
Here is part of a fountain
PostPosted: Wed Jul 10, 2013 10:36 am  (#17)
nice Sallyanne, here is my first try.
PostPosted: Wed Jul 10, 2013 6:21 pm  (#18)
GnuTux the third Image looks great and i think I'll try to reproduce it,It's good to see people giving the script a good tryout :paint
PostPosted: Wed Jul 10, 2013 7:35 pm  (#19)
GnuTux could you post a mini tute with settings on how you got the result below↓
It would be much appreciated
PostPosted: Wed Jul 10, 2013 8:33 pm  (#20)
The results in the default mode turned out great! :coolthup
With courage I will explore another time to change the settings, and check the differences.
In my example I tried to reproduce the art GnuTux.
Thx you Graechan!
bbbbbbbbbbbImage
