It is currently Sat Aug 15, 2026 5:22 pm
 Post subject: Binary gimp-plugin-morphop Gimp 64bit Win
PostPosted: Wed Jul 24, 2013 7:29 am  (#1)
Bonjour,
By AlessandroFrancesconi
http://www.alessandrofrancesconi.it/projects/morphop/
This plugin extends the GIMP's default filters "Erode" and "Dilate" with more features:
* More operators:
* Opening and Closing
* Boundary Extraction
* Gradient
* Hit-or-Miss
* Thickening
* Thinning
* Skelethonization
* White and Black Top Hat
* Possibility to change the structuring element's shape and size
Filters > Generic > Morphological operators
gimp-plugin-morphop-1.0-64bits-Win-Gimp-2.8.zip [103.41 KiB]
Downloaded 194 times
 Post subject: Re: Binary gimp-plugin-morphop Gimp 64bit Win
PostPosted: Wed Jul 24, 2013 7:43 am  (#2)
Definitely cool; use dilate/erode all the time and been using G'MIC's version since it allows for bigger radius. Will toy with this plugin when I need to do such operations for try the next oportunity. Thanks a heap samj. :)
PostPosted: Wed Jul 24, 2013 8:37 am  (#3)
(note for those who have 32 bits systems)
go to original Francesconi link where you can find the script compiled for win 32 bits
this script was already mentioned yesterday by MareroQ
samj compiled it for the lucky 64 bits users!
