It is currently Sun Aug 16, 2026 6:36 pm
 Post subject: Update to Liquid Rescale; now where's Samj? lol
PostPosted: Thu Aug 15, 2013 3:45 pm  (#1)
No compile yet for either 32 or 64-bit but still hoping Samj or anybody that has 64-bit prowess at compiling plugins can help. Got the link from GIMPUsers. :)
http://libregraphicsworld.org/blog/entr ... r-gimp-2.8
 Post subject: Re: Update to Liquid Rescale; now where's Samj? lol
PostPosted: Thu Aug 15, 2013 7:17 pm  (#2)
It's a good news Lyle!
I've never heard of 64-bit version of plugin, it would be nice to have one :bigthup .
I don't know why Prokoudine says 0.7 has incompatibility issues with 2.8.
In my 2.8.6 LQR works just fine and in the example below already got content aware functionality.
It will be included in 2.10!!! Always been saying LQR is a great plugin, and extremely underrated.
PostPosted: Thu Aug 15, 2013 8:18 pm  (#3)
I have the 32 bit compiled if you want to test it. :)
EDIT: I changed the image because the other had the old plugin view (forgot to take the exe out of my USER/gimp-2.8/plug-ins folder. This is the correct interface for Liquid Rescale 7.2. :bigthup
PostPosted: Thu Aug 15, 2013 8:23 pm  (#4)
I can try Rod; just pass on a link. Prefer just a zip; don't like to install. :)
PostPosted: Thu Aug 15, 2013 8:35 pm  (#5)
viewtopic.php?f=9&t=8267
PostPosted: Thu Aug 15, 2013 8:42 pm  (#6)
http://www.gimpchat.com/viewtopic.php?f=9&t=8267
Rod, I can't see any difference in UI between my 0.7.1 and new 0.7.2 versions.
PostPosted: Thu Aug 15, 2013 9:51 pm  (#7)
Neither did i. I believe it is mostly bug fixes for this release.
PostPosted: Thu Aug 15, 2013 10:10 pm  (#8)
I wouldn't say a bug, plugin was written at 2.6 era and not meant for 2.8. Quick fix (patch) from Prokoudine to make it work with 2.8 to be precise.
I was referring to your phrase
PostPosted: Thu Aug 15, 2013 10:44 pm  (#9)
Oh that. I had posted the wrong plugin interface image.Even though they look the same i wanted to be sure i had posted the correct one.
PostPosted: Fri Aug 16, 2013 3:57 am  (#10)
Bonjour,
@lylejk
viewtopic.php?f=7&t=8222&p=106833#p106833
PostPosted: Fri Aug 16, 2013 7:43 am  (#11)
samj wrote:
I don't think Lyle has the environment set up Sam. :)
PostPosted: Fri Aug 16, 2013 8:12 am  (#12)
@Rod
I do not know. The use of this environment make him more independent, which is appreciable.
PostPosted: Fri Aug 16, 2013 9:28 am  (#13)
Would like a 64-bit environment and maybe I might delve in the uncomfortable (at least for me). lol
Programmer I'm not and what little I did in the past life was enough to get me through. :)
PostPosted: Fri Aug 16, 2013 9:30 am  (#14)
Have to add that compiling plugins for Linux is a lot easier. I still remember compiling the Maze 5 plugin (lots of different things need to be done since it used unique stuff) with only a little sweat. :)
PostPosted: Fri Aug 16, 2013 10:20 am  (#15)
Really once the windows env is set up and it mimics Linux it is fairly easy to compile windows plugins for Gimp also. :)
Just remember were here to help if you need it. :bigthup
What i don't understand is why Gimptool-2.0 is broken for win32 now. That is sad. :(
PostPosted: Fri Aug 16, 2013 10:23 am  (#16)
What would be cool Rod is if someone would create a online PHP (think that's the term for perl script) where you upload or link the plugin that you want compiled, set either 32 or 64-bit and click a button. Not sure how hard or feasible this would be, but it sure would hope novice users like me. :)
PostPosted: Fri Aug 16, 2013 11:03 am  (#17)
@Lylejk
Compilation and programming are two very different things.
Just look on Linux where everyone compiles ;)
I might be trying to build a program that works only when using a mouse (does not tapper command line).
Another thing:
I communicate environments to try, if possible, be of interest to other users of Gimp. These environments are 32 bits for three reasons:
- There is still much more Gimp 32 bits vs Gimp 64 bits :(
- 32-bit environments are easier to create.
- Create a high-performance 64-bit environment takes time.
PostPosted: Fri Aug 16, 2013 11:07 am  (#18)
Have to add that compiling plugins for Linux is a lot easier...
For the hell of it I compiled this in Linux 32 bit and..
I know it is just update to Gimp 2.8 libraries, so (obviously) no actual benefits, the old plug-in works fine.
Big difference - the old plugin (from PCLOS) was 109,860B - the new compiled from git 425,325B
However, it does a great job as it did before. Use it a lot for DVD labels. Any development much appreciated.
PostPosted: Fri Aug 16, 2013 12:55 pm  (#19)
The only problem with that would be the possibility of "server overload". :lol
Imagine many people trying to compile many src files on one machine all at one time. :hehe
I still think the best way is a sh file.
Think about it...
You run the sh file via your cmd console. Each time you run the file all dependencies are updated from one GIT or Windows repository. You would have the correct sh file that corresponds to your system.
The script downloads or updates and installs all GIMPS dependencies needed to compile plugins.
Now all you need are the src files of the plugin. Untar or Unzip the src files.
Now in the same cmd window you just change to the src file directory that contains the configure file and type..
./configure
make ; make install OR if it's just 1 C file...
gimptool-2.0 --install [or just --build] plugin.c
Everything is built and placed in the proper installation folders. :)
Easy Peasy.
There would have to be dedicated folks to update all those dependencies of course but that could be as easy as contacting the authors of each library and asking for update information each time.
Most updates come from GLIB, BABL, GTK+, GEGL and GIMP so it shouldn't be too hard to keep dependencies correct.
Writing the SH script would be the hardest part. :) It would be quite a challenge. I did start one but... GLIB wasn't up to date and there were a few probs with GETTEXT (online probs with file names)
PostPosted: Fri Aug 16, 2013 3:17 pm  (#20)
sh would be cool if available for Windows Rod. Used it quite often enough with Linux to be more then comfortable with that. Oh well; still spiel. lol
