It is currently Mon Aug 17, 2026 12:20 am
 Post subject: 3D Shape Script or Plugin Anywhere?
PostPosted: Sat Aug 17, 2013 2:04 pm  (#1)
I'm not sure if this question was asked, so I'll go on and ask. Is there a 3D Shape Script or Plugin anywhere for GIMP users? It might come in handy if we don't want to draw things by hand.
 Post subject: Re: 3D Shape Script or Plugin Anywhere?
PostPosted: Sat Aug 17, 2013 2:37 pm  (#2)
viewtopic.php?f=9&t=5173&start=0
PostPosted: Sat Aug 17, 2013 2:40 pm  (#3)
Esper wrote:
http://www.gimpchat.com/viewtopic.php?f=9&t=5173&start=0
Thanks, Esper! :) I checked out the link and it's for 3D Text.. not shapes like circles, triangles, or squares. Is there a plugin for 3D Shapes?
PostPosted: Sat Aug 17, 2013 2:49 pm  (#4)
What do you really expect the script to do? You type "tea pot" in it and it renders a 3D tea pot?
PostPosted: Sat Aug 17, 2013 2:53 pm  (#5)
lol ofnuts, i really like tea
can you write one for me that does teapots ?!
PostPosted: Sat Aug 17, 2013 3:02 pm  (#6)
Something like that, yes but instead of a tea pot; it renders shapes.
PostPosted: Sat Aug 17, 2013 3:15 pm  (#7)
Filters->Map->Map Object might be your thing; remember to try with existing image, because otherwise you don't see a thing. :D
Also, Sphere Designer might be useful.
If you want the real thing, use Blender (free app, not Gimp plugin...).
Dang, conbagui :ninja
PostPosted: Sat Aug 17, 2013 3:16 pm  (#8)
mackenzieh wrote:
..shapes like circles, triangles, or squares. Is there a plugin for 3D Shapes?
Hi mackenzieh,
You can simulate 3D objects by using various scripts, like the one Esper mentioned, to give a 3D look to your flat image. Some scripts use extrusion to get the 3D effect, while others use beveling and shadowing to give you a 3D effect. You may also have to do some manual editing to create the highlights and reflections you need for a more realistic effect.
Most of the scripts work from a selection or path, so you should take a look at the this thread for help creating the shape, then using the various scripts at your disposal to create a 3D effect.
Don't forget about G'MIC. ;) Here are some relevant threads for you to look over..
viewtopic.php?f=8&t=2893
viewtopic.php?f=9&t=3020
Hope that helps!
PostPosted: Sat Aug 17, 2013 3:32 pm  (#9)
GnuTux wrote:
Hi mackenzieh,
Hope that helps!
Thanks, I'll take a look at the threads. I also use G'MIC as well. :)
PostPosted: Sat Aug 17, 2013 4:20 pm  (#10)
Thanks for your suggestions everyone. I will try to incorporate them all and then see what I come up with. :)
PostPosted: Sat Aug 17, 2013 5:30 pm  (#11)
Don't forget, G'MIC has a lot of support for 3D objects. Don't have time to elaborate (about to get ready for work), but other's here may. :)
PostPosted: Sat Aug 17, 2013 7:23 pm  (#12)
conbagui wrote:
the 3D text filter work with shapes too.
For the best angle use Render>Map>Map Object first
then apply 3D settings. I do it like this
This is what I get
Wilbeard! Hahaha. Nice result. Very clean compared to a lot of the ones I've seen.
