It is currently Mon Aug 24, 2026 8:49 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: EnviroMap V1.5.1
PostPosted: Fri Aug 30, 2013 6:47 pm  (#1)
Enviromap V1.5.1script assists in the rendering of environment maps suitable for use with GIMP’s Lighting Effect plug-in. The script uses a random seed, along with multiple user defined parameters, to generate endless variations of several types of environment maps. For examples of its use, see the Environment Mapped Text Tutorial.
Just create a new image with a minimum size of 400x400 pixels and run the script.
Menu Location: Filters/Render/Environment Map...
Ctrl-F will regenerate the map using a different random seed. By default, GIMP’s “Golden” gradient is used. However, you can choose any appropriate gradient to generate an environment map. The script supports the smooth topographical style map, as referenced earlier, as well as a cloud based map. You can select a Gradient or choose to use GIMP’s Active Gradient. You can blend the specified gradient back into either style map to create some unique, interesting and useful environment maps. User selects blend mode, shape and direction of gradients.
In addition, it’s useful to apply GIMP’s color setting to shift the hue or saturation/lightness on the rendered map to get the desired results for mapping.
Now supports spherical maps and interactive mapping to other objects via GIMP's map to object plug-in.
You can download EnviroMap V1.5.1 from Gimp Scripts.
 Post subject: Re: Enviromap V1.0 (Environment Map Generator)
PostPosted: Fri Aug 30, 2013 7:30 pm  (#2)
Thx! :bigthup
Testing already here! :bigthup
bbbbbbbbbbbImage
PostPosted: Fri Aug 30, 2013 7:33 pm  (#3)
Thank you sir. :)
PostPosted: Fri Aug 30, 2013 10:55 pm  (#4)
Gimp crashes when i change the gradient....
i think thats a problem we had before with some other script that Graechan wrote, and i remember there was nothing you could do about it
so the manual procedure would be to:
render Solid Noise (2,8)
Autostretch HSV
Blur 5
Map Gradient
right ?
PostPosted: Sat Aug 31, 2013 1:15 am  (#5)
You must be using GIMP V2.8.4, Esper, which is the version that had the gradient bug. It was fixed in GIMP 2.8.6, along with several other annoying bugs. You might want to consider updating. :hehe
Yes, those are the manual steps, with the addition of ensuring there is no alpha channel, which the script does too.
Maybe I should make the blur value configurable as well.
 Post subject: Re: Enviromap V1.1 (Environment Map Generator) UPDATED!
PostPosted: Sun Sep 01, 2013 1:04 am  (#6)
Updated to V1.1
Thanks to he4rty for giving me the idea to blend back in the gradient via blend modes. :bigthup
There are two variations of maps that can be rendered, both with the blend mode feature added. Combined with multiple user parameters for tweaking, this script will render endless variations of environment maps suitable for use with the lighting effects plug-in.
PostPosted: Sun Sep 01, 2013 2:01 am  (#7)
Thanks for the update, lots of settings to play with now.
PostPosted: Sun Sep 01, 2013 6:49 am  (#8)
Thank You for the updated version. This script is gold, or any other color I want, but it's gold I tell you.
PostPosted: Sun Sep 01, 2013 8:38 am  (#9)
Cool Maps ...just grabbed the script :tyspin
PostPosted: Sun Sep 01, 2013 10:16 am  (#10)
Thank you! :tyspin Was playing around with it last night. :hehe
PostPosted: Sun Sep 01, 2013 1:07 pm  (#11)
Thanks for the update Tux. :)
 Post subject: Re: Enviromap V1.2 (Gradient Shapes and Direction)
PostPosted: Mon Sep 02, 2013 6:14 pm  (#12)
Updated with support for gradient blend direction and gradient shape.
I figure more flexibility yields better results. :bigthup
PostPosted: Mon Sep 02, 2013 7:07 pm  (#13)
GnuTux have you thought about taking the next step of combining it with lighting effects and a a text to create the whole effect.
1/ Input layer should have alpha
2/ create selection and save as channel then select none and blur
3/ add layer below input layer and apply enviromap
4/ run lighting effects using channel as bumpmap and bottom layer as environment map
PostPosted: Mon Sep 02, 2013 7:33 pm  (#14)
Graechan, I have already written a stand alone logo script that I'm calling EnviroLogo, which can be used in conjunction this script, as well.
Adding in a few options to the EnviroMap script, as you suggest, might be a good option too.
I hope to post the beta version of EnviroLogo script later tonight. :bigthup
PostPosted: Mon Sep 02, 2013 9:10 pm  (#15)
Great thanks GnuTux I can replace the hack I did for creating my Images
PostPosted: Mon Sep 02, 2013 10:46 pm  (#16)
Excellent Tux! New toys to play with. :)
PostPosted: Mon Sep 02, 2013 11:35 pm  (#17)
You're welcome, Rod!
@Graechan - I like the workflow you suggest. Why don't your fork this script into another one using your method?
I'm gonna keep developing a stand alone version of this script because it can be used to generate cool patterns and backgrounds too, not just emaps.
The EnviroLogo Script I'm developing will be stand along as well. I think I'm just going to incorporate some code from this script into the EnviroLogo script, so it can generate emaps when one is not specifically selected.
 Post subject: Re: EnviroMap V1.3 (Updated: Active Gradient & Blur Final Emap)
PostPosted: Wed Sep 04, 2013 9:19 pm  (#18)
EnviroMap updated to V1.3. :hehe
Added the option to use Active Gradient in the "Map Type" drop down, per Esper's request. Selecting one of these options will direct the script to use GIMP's currently active gradient, rather than the Gradient selected in the script's input dialog.
Also, added the option to apply a Gaussian Blur to the final rendered Emap, per Rod's request.
PostPosted: Wed Sep 04, 2013 9:42 pm  (#19)
oh thank you dear sir !!
 Post subject: Re: EnviroMap V1.3 (Update: Added Active Gradient & Blur Final Emap)
PostPosted: Thu Sep 05, 2013 2:06 am  (#20)
Excellent!
