It is currently Tue Aug 25, 2026 12:53 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
 Post subject: Font to Image Hose ScriptRel4[attached]
PostPosted: Sun Oct 13, 2013 12:53 am  (#1)
Before using script make sure the DingBat license allows (most will)
Images below↓created by keeping the layers and saving as Gif animations
In the menu select a dingbat font and select the size and by default it will select all the capitol letters but you can also elect to deselect Capitols and include lower case,numerals, and control characters in the Image hose but most dingbats usually only make use of the capitals for images.
From Rel3 you also have the option to save the selected D'bat images as .gbr brushes to your brushes folder or a folder of your choice
The last option will allow you to keep the image and layers, otherwise they are deleted
When the script finishes a message will inform you where your new .gih brush has been saved
Menu Locations are Script-Fu/Brushes/Font to Image Hose and <Fonts>/
; Rel 0.02 - Added toggle control for Capitols and included Bugfixes
; Rel 0.03 - Added option to also save the layers as .gbr brushes
; Rel 0.04↓ - added ability to use active font and added menu location to <Fonts>/
'Works OK on 2.10 :bigthup '
Font to Image Hose.scm [8.19 KiB]
Downloaded 116 times
 Post subject: Re: Font to Image Hose Script
PostPosted: Sun Oct 13, 2013 1:32 am  (#2)
Graechan, It looks interesting but I'm not sure what it does.
Can you add a brief explanation for my scrambled mind?
PostPosted: Sun Oct 13, 2013 1:48 am  (#3)
Odin it does as it says
in the menu select a dingbat font and select the size and by default it will select all the capitol letters but you can also elect to include lower case,numerals, and control characters in the Image hose but most dingbats usually only make use of the capitals for images.
the last option will allow you to keep the image and layers, otherwise they are deleted
when the script finishes a message will inform you where your new brush has been saved
PostPosted: Sun Oct 13, 2013 2:15 am  (#4)
Cool! :bigthup
PostPosted: Sun Oct 13, 2013 4:04 am  (#5)
very good Graechan
PostPosted: Sun Oct 13, 2013 4:34 am  (#6)
Nice one Graechan!
PostPosted: Sun Oct 13, 2013 9:07 pm  (#7)
Thank you to all who downloaded and tried this script, and I hope all understand It's uses
PostPosted: Mon Oct 14, 2013 6:24 am  (#8)
Graechan, do you know how can I access the symbols at the wingdings fonts?
OS: Windows XP
GIMP 2.8.4
When I am in the software Word and I choose the font Wingdings I have the symbols but not when I type in GIMP. In GIMP I have only the alphabetic characters.
PostPosted: Mon Oct 14, 2013 6:58 am  (#9)
Thanks Graechan. :)
PostPosted: Mon Oct 14, 2013 7:59 pm  (#10)
Carlos Diniz This is a bug in Gimp 2.8 you can get Dingbats from Dafont
and Californiafonts all these will work fine
 Post subject: Re: Font to Image Hose ScriptRel2[Caps now optional]
PostPosted: Mon Oct 14, 2013 8:39 pm  (#11)
Script has been updated to Rel2 see initial post
PostPosted: Wed Oct 16, 2013 10:56 am  (#12)
Thanks, Graechan. I'll try it.
PostPosted: Wed Oct 16, 2013 11:30 am  (#13)
Very nice Carlos Diniz I also love the font
PostPosted: Wed Oct 16, 2013 11:31 am  (#14)
Very interesting and cool script, Graechan. Thank you.
Mr. Skello Funk font.
Zipped font attached below.
MRSKF___.TTF.zip [57.23 KiB]
Downloaded 148 times
PostPosted: Wed Oct 16, 2013 1:22 pm  (#15)
:rofl That is fantastic O!
PostPosted: Wed Oct 16, 2013 2:59 pm  (#16)
O, I love your jell-o skello.
PostPosted: Wed Oct 16, 2013 3:08 pm  (#17)
Thanks Odin and Erisian. There's also another font made by the same person called Mr. Robo Funk. I've also attached it. I did both upper and lower cases in the animation.
MRROF___.TTF.zip [25.2 KiB]
Downloaded 136 times
PostPosted: Wed Oct 16, 2013 3:15 pm  (#18)
:rofl One wonders why people spend hours making this stuff.
PostPosted: Wed Oct 16, 2013 3:38 pm  (#19)
So people like me can play with them. :hehe
PostPosted: Wed Oct 16, 2013 5:31 pm  (#20)
Very creative 'O' Mr jell-o skello is a nice animation
