It is currently Wed Nov 25, 2026 8:39 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: Snow Cover Script Rel3 [Script updated for 2-10]
PostPosted: Mon Dec 16, 2013 1:35 am  (#1)
This Script uses methods described by Hearty here, I'm a bit late to post but it slipped my Mind
Logo Menu location Script-Fu/Logos/Snow Cover Logo
Alpha Menu location Script-Fu/Alpha-to-Logo/Snow Cover Alpha
Don't forget to remove Snow Text.scm before installing Snow Cover.scm
; Rel 0.03↓ - ammended script to function in 2-10
Snow Cover.scm [12.05 KiB]
Downloaded 310 times
 Post subject: Re: Snow Covered Text Script
PostPosted: Mon Dec 16, 2013 1:57 am  (#2)
Looks good, Graechan. :bigthup
It makes a nice effects layer addition to the Logo Toolbox Script. :cool
PostPosted: Mon Dec 16, 2013 2:53 am  (#3)
GnuTux if you save the layers I think only 3 layers made up the snow and it should be easy to see how they were created or I could add a Alpha-to-Logo script but your finished Logo looks good as does the new 'Logo Workshop' update except I would have liked to see the drop-shadow as a seperate option
PostPosted: Mon Dec 16, 2013 3:06 am  (#4)
Well, I could just use the bits of code you have there to add the snow layer effect directly to the Logo Toolbox script and give you credit. I looked at your code and it will be easy to just drop right into the LT script.
By the way, you can select to do the drop shadow separately in the script or not at all. The only reason I used the approach I did was because of the lack of room on the Create Logo screen. I do have room on the Alpha to Logo screen but I was saving that space for other possible future uses.
PostPosted: Mon Dec 16, 2013 3:25 am  (#5)
Yes we are all limited by the space Wilbur has allocated
PostPosted: Mon Dec 16, 2013 12:51 pm  (#6)
Graechan, :oops: can you add alpha to logo to this script? Thanks.
PostPosted: Mon Dec 16, 2013 2:36 pm  (#7)
:wh @Graechan @GnuTux
In 2 days you both and Fencepost stumbled repeatedly against the same obstacle of dialogues size , and that also caused some delusions in who installed but could not use the scripts :bawl
Now is possible that a limit not of scheme but of the gimp implementation that use the same GUI definition from 2004 (From then were several changes regarding script fu but none regarding its GUI )
Now are excellent reasons to not change what is simple and works well ...
Till works well !!.... now we are stumbling more and more often on the same obstacle
I imagine the solution simple as add to the possible UI definitions "v-sep":
"v-sep" stand for Vertical Separator, it is simple as a vertical line , the utility of the Vertical Separator is create 2 columns instead then 1 , and so double the space available for the controls
It is not as asking support for preview, or radio button, but only for a vertical line , it seems a more then resonable enhancement request for Bugzilla and the dev list
I believe was Kevin Cozens the developer behind script fu implementation and its updates , he mayfor h even better solution
suppose he still follow gimp mailist, and his site dedicated to script and tiny fu and gimp is http://www.ve3syb.ca/software/tiny-fu/ (last update in the 2011 but were no relevant changes after )
I think may be a reasonable enhancement request
PostPosted: Mon Dec 16, 2013 6:10 pm  (#8)
D4rkheart The Alpha-to-Logo addition is nearly finished
PostPosted: Mon Dec 16, 2013 9:44 pm  (#9)
Thanks Graechan. :)
 Post subject: Re: Snow Cover Script Rel2 [Added alpha Menu, and changed name]
PostPosted: Tue Dec 17, 2013 1:41 am  (#10)
Rel2 with alpha-to-logo has been posted please see initial post
PostPosted: Tue Dec 17, 2013 3:23 am  (#11)
:tyspin
PostPosted: Tue Dec 17, 2013 3:41 am  (#12)
Nice one GnuTux, I was think about whether it could be use in a similar way as well. I guess yours answers that!
PostPosted: Tue Dec 17, 2013 8:38 am  (#13)
COOL! :) No pun intended.
Font is called "Christmas"
I used your script to create a default snow covered text. Then i selected only the text layer and ran my "Lizard Breath" script with hex and squares size 5. Then i selected just the colored text layer (Original-image-layer) , and ran color balance on JUST shadows (99 on Cyan).
Results looked like Christmas candy to me. :jumpclap
PostPosted: Tue Dec 17, 2013 8:47 am  (#14)
:tyspin graechan :tyspin
PostPosted: Tue Dec 17, 2013 8:57 am  (#15)
GnuTux wrote:
:tyspin
:teeth is all I can say about that one. :rofl :pengy
PostPosted: Tue Dec 17, 2013 9:57 am  (#16)
Added some snow on that result. Then a gradient background layer so you can see the snow better. :)
Really nice script Graechan. :bigthup
PostPosted: Tue Dec 17, 2013 10:02 am  (#17)
That text does look like Christmas candy, Rod. It's looks so tasty. :hehe
PostPosted: Sat Dec 21, 2013 4:36 am  (#18)
Cool..but what does yours Lizard Breath Script ? i am really curious to see what effect may be remind a lizard breath
PostPosted: Sat Dec 21, 2013 11:19 am  (#19)
Gnu Tux, can you share the pattern you employed at the logo "Seasons Greetings"?
PostPosted: Sat Dec 21, 2013 10:23 pm  (#20)
It's called Ice2, Carlos. I'm not sure where I got it. I'll attach.
You might want to look though the following thread too. There are some really nice patterns there.
viewtopic.php?f=12&t=9253
File comment: Ice2 Pattern
ice2.pat [56.28 KiB]
Downloaded 222 times
