It is currently Sun Aug 16, 2026 6:21 am
 Post subject: .iss
PostPosted: Tue Dec 17, 2013 6:04 pm  (#1)
I found another thing I would like to use. Wavelet denoise.
I have found the file and downloaded it but it is a .iss file and I don't know where to put it.
Any advice would be great, maybe its not the right file for me...idk!
Cheers x
 Post subject: Re: .iss
PostPosted: Tue Dec 17, 2013 6:17 pm  (#2)
It's an .exe
wavelet denoise
PostPosted: Tue Dec 17, 2013 6:23 pm  (#3)
Hi jess,
What OS and version are you running Gimp on. 32bit or 64 bit?
It should just be an exe file so I would be careful just downloading and running everything you find on the net.
I have Win 7 64bit. I can upload the exe file you need if that suits your OS.
If not once you post your details, another member can upload the correct version.
One you receive it, just place the exe file in your gimp user plugins folder.
PostPosted: Tue Dec 17, 2013 6:27 pm  (#4)
Files that contain the .iss file extension are InstallShield silent response files. These files are used by the Windows InstallShield software application. Windows InstallShield is a program that helps users install software applications on their systems and also allows developers to use a seamless installation process for their software products. link
Samj has compiled both 32bit and 64bit versions of this plug-in for Windows.
Get it here
PostPosted: Tue Dec 17, 2013 6:35 pm  (#5)
I had a tutorial I wanted to use about a year ago and it called for wavelet. After a lot of searching, I found one and with help of a real techie, I found that this plug-in was way outdated.
Needless to say I didn't do the tute. Anyway, wasn't it for smoothing skin and removing moles, or something like that? I thought there was a wavelet plug-in in GMIC too.
PostPosted: Tue Dec 17, 2013 6:42 pm  (#6)
Hi Yep, on windows 7 and I think its 32 bit.
I wanted it to lighten a photograph, as seen in another youtube tutorial. I got half way through it and didn't have the tool!
PostPosted: Tue Dec 17, 2013 6:43 pm  (#7)
G'MIC | Repair | Smooth [wavelets]
PostPosted: Tue Dec 17, 2013 7:38 pm  (#8)
What does that one do Odin, or do I have to look it up? :teeth
PostPosted: Tue Dec 17, 2013 9:18 pm  (#9)
To check whether you have 32 or 64 bit Windows, Open your Control Panel, then select System.
Then I would use the link shown in GnuTux's response above from samj.
Download the 32 bit or 64 bit version and put the exe file in your /Username/.gimp-2.8/plugins folder.
Restart Gimp and you should be ready to go.
You will find it in the Filters menu under Enhance.
