It is currently Mon Aug 31, 2026 2:48 am
Post new topic Reply to topic  [ 46 posts ]  Go to page 1, 2, 3  Next
 Post subject: Highlighting Script Rel4 (for 2.6 2.8 and 2.10)
PostPosted: Sun Jan 26, 2014 2:12 am  (#1)
This script can do highlights, Inner shadows and carved text it was only used by myself to add effects to text until Warrior spotted the effect as used in my Emap logo script, and GnuTux included a menu and some options to it so to give it a post of it's own Ive Released it now here,
it's suitable for 2.6, 2.8 and 2.10 (with all current PDB calls)
Example of highlight before and after
Images to show how it can create a beveled and cutout look
Imagehttp://gimpchat.com/styles/abbcode/images/copy.gif
N.B. shadow created by changing color to Black and inverting bumpmap
Menu location is Script-Fu/Text Effects
Rel4 Menu location is now Filters/Light and Shadows
; Rel 0.03 - (Updated By GnuTux)
; Highlight Color Option
; Highlight Opacity Option
; Merge Option
; Add Bump Map Parameters For More Granular Control Over Highlights
; Highlight Blur Option
[url=http://gimpscripts.com/2014/01/highlight/]Download Highlight Rel 0.03 from GIMP Scripts]
Highlight Rel4↓for 2.6,2.8 and 2.10
File comment: for 2-6 2-8 & 2-10
Highlight.scm [7.48 KiB]
Downloaded 208 times
 Post subject: Re: Highlighting Script Rel2
PostPosted: Sun Jan 26, 2014 2:15 am  (#2)
Tag: your shift (For GnuTux)
PostPosted: Sun Jan 26, 2014 4:31 am  (#3)
Looks good, thanks you guys! :bigthup
PostPosted: Sun Jan 26, 2014 5:59 am  (#4)
PostPosted: Sun Jan 26, 2014 6:01 am  (#5)
Nice one Graechan and Tux!
PostPosted: Sun Jan 26, 2014 8:31 am  (#6)
I tried it again, First I used the eviro map, then ran the Tux-Graechan hi-lite, duped the text and set it to multiply.
PostPosted: Sun Jan 26, 2014 10:01 am  (#7)
That is beautiful, Molly. I need to start getting more comfortable with the enviro map stuff, it really makes text good, especially with the highlight script!
PostPosted: Sun Jan 26, 2014 10:06 am  (#8)
Thanks 2-ton... I still haven't figured out all the settings yet in these newest scripts by the dynamic duo. :teeth
PostPosted: Sun Jan 26, 2014 10:15 am  (#9)
Awesome man. Thanks a lot my friend.
PostPosted: Sun Jan 26, 2014 11:07 am  (#10)
Tux,Graechan
Thank You for making my life easier :)
PostPosted: Sun Jan 26, 2014 12:02 pm  (#11)
Is it too small to see?
PostPosted: Sun Jan 26, 2014 12:18 pm  (#12)
Wow, that is cool Pirate, I must try something like that.
PostPosted: Sun Jan 26, 2014 12:20 pm  (#13)
Thank You Molly
The font is called "poke" and i used pastel rainbow gradient
PostPosted: Sun Jan 26, 2014 12:37 pm  (#14)
Excellent! This script deserved its own thread.
I've added one more option, that is to blur the Highlight layer. Blurring can soften the hard edges of the highlight and when the blur amount is set a little higher, say to 15, you get this kind of Highlight..
I've went ahead and placed the Highlight script on GIMP Scripts and updated the 1st post in this thread with the link.
Graechan, many thanks for making this available as a stand alone script. It is the perfect companion script to 3D Extrusion and for that matter, many other Text Effect scripts, as well.
(GnuTux just manages to tag Graechan as he flips over the top rope)
 Post subject: Re: Highlighting Script Rel3
PostPosted: Sun Jan 26, 2014 4:33 pm  (#15)
Nicely done guys! :)
Thank you both.
PostPosted: Sun Jan 26, 2014 7:49 pm  (#16)
Thanks GnuTux It's now a flawless script and I like the blur Option as it gives a more subtle result
PostPosted: Mon Jan 27, 2014 12:44 am  (#17)
This script rocks, I love it.
PostPosted: Mon Apr 23, 2018 2:09 am  (#18)
. :bump by Graechan
PostPosted: Mon Apr 23, 2018 4:22 am  (#19)
Thanks Graechan for a great script and to GnuTux for improving it. :bigthup
I'm wondering if Highlighting text could be applied to multiple layers and used as a video title?
Something like this on a moving background.
I think I know how to do it. Put the title at the top of the layer stack> rename it "Layer [fg]"
Process AnimStack tags and then Image>Flatten Layer Groups.
That should work. :)
PostPosted: Mon Apr 23, 2018 5:20 pm  (#20)
Just save your final tittle as a 32-bit png, then overlay it on a video track. You could get more creative if you use track masks...
