It is currently Thu Nov 19, 2026 9:18 am
 Post subject: Kirlian
PostPosted: Sun Feb 06, 2011 10:27 am  (#1)
Just an attempt at faking one anyway. Click on the image for it's Flickr. :)
ref: http://www.fontplay.com/freephotos/seventhn/fp122406-08.jpg
 Post subject: Re: Kirlian
PostPosted: Sun Feb 06, 2011 11:54 am  (#2)
The structures at the lower part reminds me of the computer simulations of the Universe's large-scale structure (yes, I'm an astronomer, so sue me). All that miniscule detail! Good one, lylejk!
Griatch
PostPosted: Sun Feb 06, 2011 12:50 pm  (#3)
Electrifyingly beautiful! So, how did you do this!
PostPosted: Sun Feb 06, 2011 3:20 pm  (#4)
Thanks Griatch/ 2-ton. I mentioned at the Flickr, but basically I used G'MIC's b/w Sketch and b/w Hardsketch with original set to color. The blendings needed to be adjusted right though (and not going to repeat right now), but when you play with these presets, I believe you will get the gist. Just remember to choose the white on black background setting for b/w Sketch. :)
PostPosted: Sun Feb 06, 2011 3:33 pm  (#5)
This is a cool effect! I used G'MIC BW Sketch (white on black on lower duplicate) and (white on transparent black) on top duplicate, added a slight blur (5px). I then pasted the original color photograph at the top and set its mode to addition (lowered the opacity of that layer to maximize bright and dark areas). Saved as a png, then opened the image again, duplicated the image, and set the top layer to addition once again to improve the brightness, with opacity adjustments.
I googled kirlian to see what the photographic equivalent was (it would be awesome if someone made a script/plug-in based on this effect).
My attempt: (thanks Lyle for sharing!)
PostPosted: Sun Feb 06, 2011 4:29 pm  (#6)
that is beautiful mahvin. The petals look like thread embroidery
PostPosted: Sun Feb 06, 2011 4:40 pm  (#7)
Stunning! I must try this too!!
My Sigs = My Photos
PostPosted: Sun Feb 06, 2011 8:56 pm  (#8)
I set the sliders to what looks good on the preview, then when I apply it it looks awful on the layer itself, nothing like what the preview looked like.
PostPosted: Sun Feb 06, 2011 11:18 pm  (#9)
Yeah; that's the problem with G'MIC; you have to play enough with the sliders to know what will probably look like based on the preview; takes practice. lol
