It is currently Thu Nov 19, 2026 5:34 am
 Post subject: Signature of the week... My Second Entry...
PostPosted: Sun May 02, 2010 2:34 pm  (#1)
Okay so it's a new week.. The theme this week is... WATER
I just entered the contest with a basic but nice sig I guess..
I myself am a scuba diver
So I took the word "water" that way...
Let me know what you think of it.. I like it..
Regards
 Post subject: Re: Signature of the week... My Second Entry...
PostPosted: Sun May 02, 2010 3:46 pm  (#2)
I love the light source! It looks like the sun is shining from above. :bigthup
Why don't you try the under water script from that under water pearls thread molly posted? :)
PostPosted: Mon May 03, 2010 8:34 am  (#3)
yah, I think that would be cool......
PostPosted: Mon May 03, 2010 11:10 am  (#4)
Linky :bigthup /beg
PostPosted: Mon May 03, 2010 11:17 am  (#5)
wave tank
This is a little tute Oregonian wrote out for me so here it is...
Using the Wave Tank script
1. Open a new transparent layer.
2. Fill the background layer with the silver environment map.
3. Make a new layer and fill it with blue or whatever color you want to use.
4. Set the layer mode to the one that looks best to you over your background.
5. Merge the color layer down to the background layer.
6. Make a new transparent layer and put the image or make text like you want.
7. Color the text how you want.
8. Bevel and dropshadow the text how you want.
9. Merge the text layer down to the dropshadow layer if you've made a dropshadow.
10. Make a new transparent layer and fill it with the same blue you used previously.
11. Lower the opacity until your text has the tint of blue you want.
12. Merge that layer down to your text layer.
13. Merge that layer down to the background layer.
14. Run the wave script. I used 25 frames in mine and left the rest of the settings default
PostPosted: Mon May 03, 2010 11:20 am  (#6)
viewtopic.php?f=9&t=177
search, or just looking through the recent threads works very well too. :bigthup
PostPosted: Mon May 03, 2010 11:22 am  (#7)
Jolie wrote:
http://gimpchat.com/viewtopic.php?f=9&t=177
I'm lazy today :mrgreen: Sry
PostPosted: Mon May 03, 2010 11:23 am  (#8)
Moving signatures are not allowed :(
I tried it anyway and It didn't realy work.. I applied the script then saved as .GIF and it doesn't move :(
What did I do wrong :cool
PostPosted: Mon May 03, 2010 11:59 am  (#9)
Did you save the gif as an animation or did you tell it to flatten? There is an option when saving to specify flattened image or animation.
PostPosted: Tue May 04, 2010 2:49 pm  (#10)
Saving as an animation.
