It is currently Thu Nov 19, 2026 5:32 am
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Just playing...
PostPosted: Wed May 19, 2010 6:10 am  (#1)
...while waiting for inspiration :paint2
 Post subject: Re: Just playing...
PostPosted: Wed May 19, 2010 6:22 am  (#2)
jenx, very nice effect. How did you make the splatters
PostPosted: Wed May 19, 2010 6:57 am  (#3)
Thanks, molly.
For the splatters draw sparks on a new transparent layer ("sparks")...
Adjust ALPHA curve...
Protect transparency and fill with gray (#888888)
Copy layer and rename it "bump"
Create a colored layer as you like (e.g. with plasma),
put it before the sparks layer and set its mode to color...
Merge it down...
Apply gaussian blur to the "bump" layer (value 20.0)
and use it for bump mapping the sparks layer
The result should look like this...
PostPosted: Wed May 19, 2010 9:35 am  (#4)
oh thank you very much. I think I will print that and try it. :clap
PostPosted: Wed May 19, 2010 11:42 am  (#5)
Nice!
How did you make the ball? Looks very good. :mrgreen:
PostPosted: Wed May 19, 2010 1:45 pm  (#6)
hee hee, a lovely little tutorial to try out today. I am thinking it would make a nice 'water' splash look, not sure what colors to use for that, though.
PostPosted: Wed May 19, 2010 5:13 pm  (#7)
took a bit of fiddling, but realized that I have to untick the keep transparency box before I blurred, lol.
I tried to so one that looked like water, but it doesn't seem to work with any color lighter than the grey.
PostPosted: Thu May 20, 2010 1:08 am  (#8)
You got it, 2-ton :clap
This is how I made the ball:
Start with a new square(!) image (400x400).
Color it as you like. I used plasma for this.
Apply the mosaic filter to it.
For the next filter I don't know the english title.
Maybe "movement blurring"
Anyway ... apply it :)
The result should look like this one
Now map that image to a sphere...
You got the ball...
Adjust colors as you like, add a drop shadow ...
PostPosted: Thu May 20, 2010 4:04 am  (#9)
Jenx.
That is a very well put together tute...... thanx.
PostPosted: Thu May 20, 2010 10:35 am  (#10)
I hope you continue, "just playing," jenx. This is a very nice outcome. Thank you for sharing.
I put the ball into the sparks image and it fell under the sparks layer. I liked it like that so I left it that way ... it looks like clouds over the ball. Kind of a surreal, alien world look.
My mosaic filter is different from yours. The tiles had transparency between them so I put a black layer under it and merged the layers. It worked out fine except mine threw in a few little black lines on some of the tiles.
LATER EDIT: I looked at the mosaic filter again and unchecked allow tile splitting. That removed the extra little black lines (splits) on some of the tiles. I made just a ball and it has no dark smears on it.
Here it is with the sparks layer under the ball.
PostPosted: Thu May 20, 2010 11:38 am  (#11)
excellent.....
PostPosted: Thu May 20, 2010 2:45 pm  (#12)
Jenx, I'm loving the ball. :mrgreen:
I make video tutorials on youtube, if I run out of ideas one day, can I use that tutorial of yours? :) Fully crediting you for the tutorial itself of course.
PostPosted: Tue May 25, 2010 4:24 am  (#13)
Sure, jolie.
Use it as you want. Credit isn't neccessary. Most things we do are compilations of other tutorials. If we would give credit to any pixel in our pictures to every applied tutorial, the lists would get somewhat huge...
PostPosted: Tue May 25, 2010 4:31 am  (#14)
@2-ton: you will create water effects like this?
It's based on this tutorial.
Have fun...
PostPosted: Tue May 25, 2010 7:03 am  (#15)
jenx,
Looks like a very nice tutorial. I have it all printed ready to try.
:coolthup :coolthup
PostPosted: Tue May 25, 2010 9:43 am  (#16)
Thanx, J..., looks like a good tut.
*oops, spoke too soon. I quickly tried to go through it but sort of got lost about which layers to do what to after the new channel was made. I need baby steps.
PostPosted: Tue May 25, 2010 10:52 am  (#17)
you sound like me 2-ton. The part that is missing is always the one I screw up on. lol.....
PostPosted: Tue May 25, 2010 11:04 am  (#18)
I'm basically not clear about which layer I should be on at which step. Now I have to go to work, so it will be late when I try again. Argh, I still haven't gotten the apng stuff to work!!
PostPosted: Wed May 26, 2010 12:03 am  (#19)
*is still looking for the sparks filter* =P
PostPosted: Wed May 26, 2010 12:10 am  (#20)
hi rod, "sparks" is a brush, not a filter. Look for a yellow brush...
