It is currently Wed Sep 30, 2026 3:22 am
 Post subject: Appearance of my Gimpchat
PostPosted: Fri Jan 07, 2011 11:40 pm  (#1)
Can someone suggest if there is a way to change the appearance of my Gimpchat interface (Yes, I mean Themes)? I am finding the default theme to be wasting space on my screen with big and bold letters etc.
My photostream: http://flickr.com/neychurluvr/ | I have plenty of CC licensed pictures for your use :-)
 Post subject: Re: Appearance of my Gimpchat
PostPosted: Sat Jan 08, 2011 4:18 am  (#2)
You can not change the color theme. but you can change the way things are displayed via your user profile link under board pref/display options.
PostPosted: Sat Jan 08, 2011 4:22 am  (#3)
You may be able to change it (the CSS file) in your own browser via Web Developer add-on plug-in for Mozilla.
PostPosted: Sun Jan 09, 2011 1:32 am  (#4)
thanks Rod for the kind responses. i am more looking for the themes kinda stuff. anyways i will try to get used to this for now.
