It is currently Sat Oct 10, 2026 12:58 pm
 Post subject: how do i open the scripts folder on gimp (i use windows)
PostPosted: Sun Mar 13, 2011 6:38 pm  (#1)
so how do i do it?
 Post subject: Re: how do i open the scripts folder on gimp (i use windows)
PostPosted: Sun Mar 13, 2011 6:41 pm  (#2)
Start>My Computer>Local Hardrive (C)>Program Files>GIMP-2.0>Share>GIMP>2.0>Scripts
Enjoy
I'm back I think
PostPosted: Sun Mar 13, 2011 6:42 pm  (#3)
C:/program files/Gimp2.0/share/gimp/2.0/scripts
PostPosted: Sun Mar 13, 2011 6:43 pm  (#4)
Got it covered Nixnine
I'm back I think
PostPosted: Sun Mar 13, 2011 6:49 pm  (#5)
ya i figured it out but thx anyways lol
PostPosted: Sun Mar 13, 2011 7:31 pm  (#6)
It also depends on whether you are set up for single user or system wide. And if you are speaking of the existing GIMP scripts that come with GIMP, or new ones you add to GIMP.
From experience, I tend to avoid using the "system wide" folders in Program Files. The reason, is because you stand a good chance of losing any scripts you add there when you uninstall GIMP, for any reason. So if you are using the system wide location in Program Files, make back-ups of your scripts. Or avoid all that by adding them to the single user location at C:\Users\username\.gimp-2.6\scripts (Vista and 7).
It just makes more sense to use the single user location, for the off-chance you have to uninstall GIMP, you won't lose your scripts. This goes for plug-ins, too (in the plug-ins folder, of course).
PostPosted: Sun Mar 13, 2011 7:42 pm  (#7)
I'm good man. Don't need any help. I got it covered too.
PostPosted: Sun Mar 13, 2011 8:10 pm  (#8)
You are also a lot more likely to make regular backups of your personal disk space than of the system disks.
PostPosted: Mon Mar 14, 2011 3:35 pm  (#9)
The only fall back is you may after updating Gimp to the newest version have a script that will no longer run or has some deprecated code.
The best place to put all new downloaded scripts, plug-ins, or windows binaries is in the user docs gimp-2.0 sub directory folders whatever system platform you use.
PostPosted: Mon Mar 14, 2011 3:36 pm  (#10)
This is sorda on topic with this... How do you install G'MIC in the Portable GIMP? Anyone know? I tried and it won't work...
I'm back I think
PostPosted: Mon Mar 14, 2011 3:42 pm  (#11)
You may have to copy a few of the Gimp-2.0 dll files to that portables app/bin folder Willy.
I have never tried this though so do it at your own risk :lol
PostPosted: Mon Mar 14, 2011 3:43 pm  (#12)
Well I did it, and re arranged some stuff, and nothing happened :lol so I don't know if I can really Break GIMP, but hopefully someone can tell me what I need to move, I am not really that Techy to figure it out
I'm back I think
PostPosted: Mon Mar 14, 2011 3:46 pm  (#13)
Don't move anything - copy and paste to insure you do not mess up Gimps core files.
I advise to make a list of things you copy and paste also.
Welcome to the world of de-bugging :lol
PostPosted: Mon Mar 14, 2011 3:49 pm  (#14)
Yeah... bit late for the Do not "move" I didn't "move" I did Copy and Paste, but... I have no idea what all I moved, I am thinking about taking the whole GIMP 2.0 Scripts Folder and replacing the one in Portable with that one...
I'm back I think
PostPosted: Mon Mar 14, 2011 9:25 pm  (#15)
You could probably do that or i believe there is a zip with all the default scripts at deviant art.There is also a plug-ins zip there too i think?
scripts folder - http://www.deviantart.com/download/1005 ... ources.zip
plug-ins i couldn't find sorry
PostPosted: Mon Mar 14, 2011 9:29 pm  (#16)
Found it - http://www.deviantart.com/download/1005 ... ources.zip
PostPosted: Mon Mar 14, 2011 9:32 pm  (#17)
Here is a link you may find pretty cool
http://ilkka-yo.deviantart.com/art/GIMP ... ugins&qo=2
PostPosted: Tue Mar 15, 2011 6:49 am  (#18)
Best way to install plugin in gimp gimportable, gimpainter etc is:
extract gmic (or mathmapor whatever ) in a dedicated folder, WHERE YOU LIKE
load gimp go to Edit/Preferences/folder/plugin there click first "new folder" icon and then "search" icon to add the path for that folder (more easy do then explain)
Obviously for the portable if is installed on the main HD, the folder may be everywhere you like, but if you run the portable from a USB drive the folder should also be in the USB drive
For gmic you may also use the installer just is better point the installer to a new dedicated folder, not to one already in use
If you use the zipped version you should extract everything not only the exe
