It is currently Sat Oct 17, 2026 9:08 pm
 Post subject: If you are happy with Win7 SP1, then...
PostPosted: Thu Apr 05, 2012 6:35 am  (#1)
...you can gain back a lot of HD space by running the following at the command prompt (need to run command prompt as administrator by right clicking and choosing that option when you execute command prompt): C:\Windows\System32\DISM /online /Cleanup-Image /SpSuperseded
I got this tip from my Window's Secrets newsletter email. It saved around 5Gigs of harddrive space for me; not too shabby. Figured it's been over a year since I upgraded to SP1 so why not. :)
 Post subject: Re: If you are happy with Win7 SP1, then...
PostPosted: Thu Apr 05, 2012 6:52 am  (#2)
Forgot to add that it took over 10 minutes on my PC. Just wait until the operation is 100% complete before ending command prompt. :)
PostPosted: Thu Apr 05, 2012 8:11 am  (#3)
Thanks, I guess i will do that too even though i still have 216 GB free
PostPosted: Thu Apr 05, 2012 9:54 am  (#4)
10 minutes to erase 5GB? This ain't a file system. This is a file dormitory.
PostPosted: Thu Apr 05, 2012 12:53 pm  (#5)
Can you pm me that newsletter link?
PostPosted: Thu Apr 05, 2012 1:15 pm  (#6)
No need to PM you Zward117; the link to the particular part of the letter is below. I use to subscribe the the Langalist newsletter since 1998; Fred since joined forces with Windows Secrets and I decided to do a lifetime subscription since they've always giving me good info (past 5 or 6 years that is). The info from the newsletter is what I posted earlier. :)
http://windowssecrets.com/langalist-plu ... n-to-size/
PostPosted: Thu Apr 05, 2012 1:17 pm  (#7)
Which 5gigs of your data does it erase? :)
EDIT: Never mind i just read the article.
PostPosted: Thu Apr 05, 2012 1:24 pm  (#8)
Only the ones associated with Win7 OS prior to Win7 sp1 Rod. This folder is only good for quick recovery if you need to go back to a state prior to sp1 when you do this. Don't blindly delete any of the files in this folder of course; that's why I used the command line to do it. Don't think you can anyway since the folder is a Windows protected one. :)
PostPosted: Thu Apr 05, 2012 1:33 pm  (#9)
Wish there was something like this for XP. :)
PostPosted: Thu Apr 05, 2012 1:44 pm  (#10)
Yeah; XP actually allows you to directly delete content in WinSxS directly which is very dangerous. You can safely delete most OS update uninstall folders ($NUninstallk***** folders) but if you do so, you won't be able to remove those particular updates. I always delete the last month's updates once I install the current month's updates to save HD space Rod. Figure if my OS is working fine, then why do I care if I can uninstall these updates. lol
PostPosted: Thu Apr 05, 2012 1:49 pm  (#11)
lol :)
PostPosted: Thu Apr 05, 2012 1:59 pm  (#12)
This article is part of our paid content. Subscribe.
In Linux we don't suffer from this kind of problem,you never have to defrag your disks for instance.
And if we did there would be oodles of articles,forums with free solutions.
Reminds me of the DOS era where technical writers wrote large books about "hidden" stuff in DOS.
Not for free of course.
Gerard.
Gimp-2.8.14
I use Linux only.
And Virtualbox with Win 7
PostPosted: Thu Apr 05, 2012 2:06 pm  (#13)
I'm sure if you are willing to dig, you would find the same info Gerard. I only linked it since it was requested. I'm a PC guy so I do subscribe to both free and not free newsletters that are PC related. PCs are going to be a dieing breed once the smart phones and pads become the mainstream; that, I do believe. Still, I don't mind paying for content if it's important to me, but do agree that free is better. lol
PostPosted: Thu Apr 05, 2012 3:32 pm  (#14)
whoops lol
still too much you can't do from a smartphone to get rid of the PC.
I'm back I think
PostPosted: Thu Apr 05, 2012 8:10 pm  (#15)
I did refuse to believe that PCs would die too, but then, when I wanted Perculator and asked the creator to port it to Windows (it's and iPod and iPad app), he said he was thinking about doing so for Mac maybe but would do so for PCs. That's when I realized that PCs is a dieing breed. lol
PostPosted: Fri Apr 06, 2012 5:46 am  (#16)
All the more reason to switch to Linux.
Gerard.
Gimp-2.8.14
I use Linux only.
PostPosted: Fri Apr 06, 2012 6:31 am  (#17)
YES!
PostPosted: Fri Apr 06, 2012 7:11 am  (#18)
Linux is not as vulnerable as most other OS's.
But it is possible.
Install "chkrootkit" and run it in a terminal like so:
sudo chkrootkit | less
Less is needed to show the output page by page.
It is not an antivirus program,it just shows infections.
Gerard.
Gimp-2.8.14
I use Linux only.
