It is currently Wed Oct 07, 2026 6:34 am
 Post subject: Well wish me luck!
PostPosted: Thu Dec 09, 2010 1:55 pm  (#1)
I downloaded the Ubuntu iso (700mb) wubi side by side install for testing it out.
Now i shall install it ... hopefully all goes well.
You will know soon enough...lol
Here goes! =P
 Post subject: Re: Well wish me luck!
PostPosted: Thu Dec 09, 2010 2:07 pm  (#2)
Got fingers and toes X'd for you. Break a leg!!
PostPosted: Thu Dec 09, 2010 2:27 pm  (#3)
Just so you know, Rod. Wubi is very unstable, especially with updates and GRUB issues.
I would strongly suggest you create a Live CD just in case you find an update terrorizing your GRUB configuration and preventing you from logging in.
PostPosted: Thu Dec 09, 2010 3:51 pm  (#4)
I can not even get the installer to start.
I guess there are issues with the python dll file loaded with it.
I even tore the installer apart with 7zip....not able to start it that way either.
Probably a good thing.....lol =)
Gonna go your way mahvin, thanks!
@O ... thanks for even crossing your toes. =)
PostPosted: Thu Dec 09, 2010 5:18 pm  (#5)
Well now my dog gone cd door will not open, must be a sign.
I guess i'll be sticking with Windows XP after all. =)
I will send for the live cd for ubuntu-10.10.iso though.
Maybe at the end of the year when i have a newer machine i'll have another go at it.
PostPosted: Thu Dec 09, 2010 7:44 pm  (#6)
I downloaded the 64-bit Ubuntu a few weeks ago, installed it and it actually worked until I had to get updates. The updates refused to work and I kept getting errors when trying. I promptly removed that VM and sticking with Lynx. I've heard a lot of complaints with Meerkat; going to wait til the next version before trying again (Lynx will be supported for up to 3 years, so I have some time). I only have occasion (but do have occasion) to use Ubuntu for a few specific plugins which I have no Windows compile for. Actually made a compile for Maze5 (and had to use their custom compiler). Still can use the online convertor (arguably better, but I like to use programs that are local; much faster). Below's a link to that site. :)
http://maze5.sourceforge.net/create_maze.html
PostPosted: Fri Dec 10, 2010 12:19 am  (#7)
Wow that's really cool! =)
I made a small one..lol
PostPosted: Fri Dec 10, 2010 1:43 am  (#8)
Cool thing about the online version is that you can export to PDF, SVG, PNG or other bitmaps (I prefer vector of course since GIMP can port them and also cleanly scale those results). Hope you don't mind me using your snowman avatar as inspiration for this one. :)
PostPosted: Fri Dec 10, 2010 2:22 am  (#9)
Tried a black and white image of a Christmas tree shape.
This is an svg file. Hope the image tags work. They don't. You'll have to click the link to view it.
http://gimpchat.com/o/Album-gc/maze.svg
PostPosted: Fri Dec 10, 2010 1:11 pm  (#10)
Like the Christmas tree maze O. By the way, I didn't mean to steal the thread from you Rod. lol
PostPosted: Fri Dec 10, 2010 1:18 pm  (#11)
not a problem. =)
PostPosted: Fri Dec 10, 2010 2:09 pm  (#12)
@Rod,
If you haven't resolved your CD drive door problem, you might try creating a bootable USB thumb drive and burning the iso to it, if your BIOS can be set to boot from USB. I have an old 1GB thumb drive that is perfect for this like when I want to test-drive a new distribution, as most Live CDs are 700MB. I usually use UNetbootin to create the bootable drive - and it is available for Windows and Linux.
You can get it from Sourceforge here:http://unetbootin.sourceforge.net/
Life Truth: #12
