It is currently Sat Aug 15, 2026 5:58 pm
 Post subject: Help in restoring these photos
PostPosted: Fri Dec 05, 2014 3:03 pm  (#1)
I would like help in restoring these photos. Any help would be great.
 Post subject: Re: Help in restoring these photos
PostPosted: Fri Dec 05, 2014 4:49 pm  (#2)
It will be hard to get good results with so few pixels in the image. If you can get a larger scan, that would help. Here's what I was able to do with several noise reduction filters in G'MIC, plus color correction and some cloning and smudging.
And when all else fails, there's FotoSketcher :)
PostPosted: Fri Dec 05, 2014 4:57 pm  (#3)
mackenzieh, I'd like to have got a better outcomes but as Acmespace says there are few pixels. Here my tries.
Good improvement Acmespace . :bigthup
2912_nataliamagazinescan-noise reduction+enhancement.jpg [ 32.59 KiB | Viewed 5406 times ]
PostPosted: Fri Dec 05, 2014 5:07 pm  (#4)
Thanks Issabella & Acmespace, I will give it a try and see if I can come up with something.
After figuring out what filters work, I got these results:
Most of the photos I used the plugin ISO Noise Reduction. The first photo I used the beautify plugin and a few of its filters.
PostPosted: Fri Dec 05, 2014 9:54 pm  (#5)
my tries
PostPosted: Fri Dec 05, 2014 9:58 pm  (#6)
Nice work Sallyanne. :) I think I have the hang of restoring photos.
PostPosted: Sun Dec 07, 2014 3:11 am  (#7)
I understand you better like to get indications, more than final solution.
Hence my suggestions:
1-separate the image into different areas (in the example shown below I separated skin areas from background and hair
2-use different tools for the different areas (in the example below I used gaussian blur 15 on the background, G'MIC smooth mean curvature on the skins, a detail increase on the hair)
3-at the end apply some colour improvement
Here an applied example (roughly performed, don't consider it an optimum result, you can get better outcomes with patience...)
PostPosted: Sun Dec 07, 2014 3:16 am  (#8)
Thanks for the tips. I actually have my restored photos and I like the way they turned out. :)
PostPosted: Sun Dec 07, 2014 1:27 pm  (#9)
layer mask on different tone and smoothing
