It is currently Tue Nov 17, 2026 5:00 am
 Post subject: Nik Collection
PostPosted: Sun May 08, 2022 12:13 am  (#1)
Looks like google has found a way to stop us using the once free collection. I used define a lot for photo enhancing.
I cannot get rid of this from my screen
I saved the Collection from when I got it for free and when I got a new computer put it in there. All went well until a few hours ago.
 Post subject: Re: Nik Collection
PostPosted: Sun May 08, 2022 3:35 am  (#2)
Hi, I have the same one on it but still works fine, no problems.
PostPosted: Sun May 08, 2022 5:28 am  (#3)
That happened to me less than 24 hrs ago and I had used it the day b4
PostPosted: Sun May 08, 2022 5:48 am  (#4)
It is the "About" splash when you click on the Define2 area. Does it go away when you hit the ESC key ? It does here.
PostPosted: Sun May 08, 2022 7:33 am  (#5)
Never had the 'splash before' I'll check and edit my post with the results
EDIT:
I was able to close it rich, earlier, by shutting down my computer completely.
All of the filters in the Nik Collection opened and closed normally just then. Weird though that I only just got the splash opened yesterday.
By the way the splash never opened up this time for any of them.
