It is currently Sun Aug 16, 2026 4:48 am
 Post subject: Release of G'MIC 1.6.8
PostPosted: Mon Dec 07, 2015 7:34 am  (#1)
Hello folks,
I've released a new version of the G'MIC plug-in for GIMP, numbered 1.6.8.
You can read the changelog here : https://discuss.pixls.us/t/release-of-gmic-1-6-8/470
A lot of small bugs have been fixed, as well as various optimizations, so do not hesitate to upgrade,
particularly if you were using a version older than 1.6.7 !
 Post subject: Re: Release of G'MIC 1.6.8
PostPosted: Mon Dec 07, 2015 8:26 am  (#2)
As always, thanks for the update, David. :)
PostPosted: Mon Dec 07, 2015 9:38 am  (#3)
Thank you sir!
PostPosted: Mon Dec 07, 2015 2:27 pm  (#4)
Thank you David. :bigthup
:coolthup
PostPosted: Mon Dec 07, 2015 3:10 pm  (#5)
David,
Installed and working.
Many thanks for your hard work.
david.
PostPosted: Tue Dec 08, 2015 12:14 am  (#6)
After updating, I appear to have 3 less filters in the count. Thankfully the ones missing aren't in my faves.
PostPosted: Tue Dec 08, 2015 1:19 pm  (#7)
Thank you David, for the early Christmas present. :bigthup
PostPosted: Wed Dec 09, 2015 2:42 am  (#8)
Thank you.....does this have a windows installer?
PostPosted: Wed Dec 09, 2015 3:51 am  (#9)
Hi Deblk - if you check out this download site, you will see installer and zip files for both 32 and 64 bit Windows ...
http://gmic.eu/gimp.shtml
PostPosted: Thu Dec 10, 2015 3:18 am  (#10)
Thank you...i did have a look before but think I have now found what i am looking for :)
PostPosted: Thu Dec 10, 2015 5:32 am  (#11)
by clicking on the first line you get the installer (64bits or 32bits, which one you need)
(only if you click specifically on "zip file" you get the zip file)
PostPosted: Fri Jan 22, 2016 5:14 am  (#12)
I have been receiving this:
The connection has timed out
The server at gmic.eu is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few moments.
If you are unable to load any pages, check your computer's network connection.
If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
when trying to access http://gmic.eu pages for the last several days
http://www.downforeveryoneorjustme.com/gmic.eu says the site is up…
Any idea what could be wrong?
PostPosted: Fri Jan 22, 2016 8:11 am  (#13)
Opened for me straight away. Maybe a lot of people in your area are using it when you try - only thing I can think of.
PostPosted: Fri Jan 22, 2016 8:16 am  (#14)
Works for me also. No problems whatsoever. :)
PostPosted: Fri Jan 22, 2016 9:27 am  (#15)
Thanks for the quick replies folks, apparently the one time it partially worked (accessing the site from the update filters feature which usually has given "Filters update from Internet (partially) failed ! / Unable to reach these filters sources: / * http://gmic.eu/gimp_update1661.gmic" ) it "broke" the installation enough I needed to remove both GMIC & Gimp, do a system restore and reinstall UGH!.
From what I've read while slowly beating WinDoze into submission during the restore, I need to download 1.6.8 as an exe and install it anyway…
The inability to reach any pages @ h^^p://gmic.eu [or h^^ps://gmic.eu ] has been consistent since sometime late last week and has occurred at all hours of the day, which suggests to me local congestion is unlikely to be the cause.
The issue also occurs consistently with the Chrome browser (normally using Firefox 43.0.1)
Wondering if NoScript settings (which I've been getting stricter about) could be influencing this…??? although I tried a few times with it globally disabled which ought to remove it as a problem…
This seems doubly unlikely as I have the same problem with time-outs on a MAC without NoScript…
I've not yet tried through someone else's connection and probably won't get a chance until Saturday
Is there any other source for the windows G'MIC installer? (ie not on h^^p://gmic.eu )
split topic to here viewtopic.php?uid=4148&f=28&t=13575&start=0
PostPosted: Sun Jan 24, 2016 4:02 am  (#16)
I like this effect a lot. GMIC is fantastic! :bigthup
