It is currently Sun Nov 29, 2026 6:23 pm
 Post subject: blend_seamless by command line
PostPosted: Thu Feb 25, 2016 5:48 am  (#1)
Hi all
Could you help me to merge properly a little pattern image into a bigger one using blend_seamless option of command line at custom position?
With this basic command-line, I cannot select the position: pattern is copied at the center of bigger one.
$> gmic -i road.jpg -i car.png --blend_seamless[0,1] 0,10%,4% -display
Except position, it works well!
I tried this (put pattern into big empty image before seamless blending), but it fails:
$> gmic -i road.jpg -i 800,600,1,4 -i car.png --blend[1,2] alpha --blend_seamless[0,3] 0,10%,4%
It seems the seamless blending can not operate on largely empty image pattern.
road.jpg and car.png are attached.
Thanks for help!
 Post subject: Re: blend_seamless by command line
PostPosted: Thu Feb 25, 2016 8:04 am  (#2)
Never tried custom set - up for this but it actually works. Seam-lessy blending into the background.
I will try and show you what I get
Opening both layers then G"MIC, scrolling down to layer's, blend seamless, making sure input layers is set to all. This is what I got
PostPosted: Thu Feb 25, 2016 9:23 am  (#3)
Yes, I get the same result with the GMIC plugin for GIMP, but I really need to use the command line. I would like to blend the same pattern in a large set of images, by shell script.
I'm pretty sure I missed a command option!
PostPosted: Thu Feb 25, 2016 9:33 am  (#4)
One way to do this, is to resize your foreground sprite first, then shift it with the desired coordinates you want for the location :
$ gmic road.jpg car.png -r. [0],[0],1,4,0 -shift. 150,200 -blend_seamless
Here, replace 150,200 by the coordinates you want.
PostPosted: Thu Feb 25, 2016 9:50 am  (#5)
Nice, this is exactly what I want!
$> gmic -i road.jpg -i car.png -r[1] [0],[0],1,4,0 -shift[1] 200,200 --blend_seamless[0,1] 0,10%,4% -display
Thanks!
