 Post subject: GIMP-2.9.6
PostPosted: Sun Aug 27, 2017 7:26 am  (#1)
I really love the split view in the GEGL plugins. :)
 Post subject: Re: GIMP-2.9.6
PostPosted: Sun Aug 27, 2017 3:46 pm  (#2)
Hi Rod,
This is good news!
I have found the address of the Win 'gimp-2.9.6-x64-setup.exe' file at 'https://plus.google.com/+gimp'.
PostPosted: Sun Aug 27, 2017 7:57 pm  (#3)
Looks like Christmas is getting a little closer! :gimp
https://download.gimp.org/pub/gimp/v2.9/windows/
PostPosted: Mon Aug 28, 2017 12:13 am  (#4)
Sweet!! I just downloaded this version for Windows and will probably try it out tomorrow.
My Sigs = My Photos
PostPosted: Mon Aug 28, 2017 8:00 am  (#5)
Rod, in my 2.9.6 there is no Gegl Mosaic
Windows 10 64bits
PostPosted: Mon Aug 28, 2017 8:15 am  (#6)
Windows 10 64bits
Look under "Filters>Distort>Mosaic" ;)
I am using the GIMP-2.9.6 64 bit Windows executable installer file directly from Gimp.org downloads.
PostPosted: Mon Aug 28, 2017 8:24 am  (#7)
Yes, there is, but I wanted to use GEGL operation like you did
edit: oh, I see it's there, in the usual menu, but it makes use of Gegl
PostPosted: Mon Aug 28, 2017 8:27 am  (#8)
See the G next to the filter name? It is a GEGL filter now. :)
PostPosted: Mon Aug 28, 2017 8:32 am  (#9)
OK, thanks Rod.
