 Post subject: Party Balloon Brush Pipe
PostPosted: Sun Oct 14, 2018 1:23 pm  (#1)
Here's a Party Balloon Brush Pipe.
There are 7 balloons to this brush and it paints incrementally.
Below is a preview image of the .gih Brush Pipe.
This is a complete brush,
with shadows and opacity adjustments already added.
Party_Balloons.gih [8.86 MiB]
Downloaded 485 times
 Post subject: Re: Party Balloon Brush Pipe
PostPosted: Sun Oct 14, 2018 1:41 pm  (#2)
Downloaded it and I like it. It can work on a white background where the brush produces no string, just light colored balloons. It works best on a colored background.
PostPosted: Sun Oct 14, 2018 1:44 pm  (#3)
Thank you Wallace. I downloaded the brushes. Got a few birthday cards to make for children in my family :tyspin :hbd
PostPosted: Sun Oct 14, 2018 3:40 pm  (#4)
You may need to check the setting on the brush,
or the layer below.
This is what the brush looks like,
on a white background in GIMP 2.8.
PostPosted: Sun Oct 14, 2018 4:40 pm  (#5)
Thank you for sharing Wallace. :yes
PostPosted: Sun Oct 14, 2018 6:01 pm  (#6)
or the layer below.
I will check that when I use it. Thanks Wallace.
PostPosted: Sun Oct 14, 2018 6:16 pm  (#7)
or the layer below.
PostPosted: Sun Oct 14, 2018 10:45 pm  (#8)
Nice brush, Wallace. :)
PostPosted: Sun Oct 14, 2018 11:09 pm  (#9)
Thanks Lyle.
That's a lot of balloons.
PostPosted: Mon Oct 15, 2018 12:33 am  (#10)
Thank you so much for sharing the balloon brush with us Wallace. You do very nice work. We appreciate it.
BTW, I had a feeling that Lyle would do something like with the balloons, as he has done with many other items!!
PostPosted: Mon Oct 15, 2018 12:37 am  (#11)
No problem Pat625,
that's what it all about and thank you.
PostPosted: Mon Oct 15, 2018 1:18 am  (#12)
I changed the 'Force' setting on the balloon brush when I used it on a white back ground. The strings do show up.
PostPosted: Mon Oct 15, 2018 1:43 am  (#13)
mackenzieh wrote:
I changed the 'Force' setting on the ballon brush when I used it on a white back ground. The strings do show up.
Nice!
:jumpclap
Sometimes you have to play around with the setting.
I always leave my brush settings at their default,
and things just seem to work better for me that way.
PostPosted: Mon Oct 15, 2018 1:56 am  (#14)
Nice!
:jumpclap
Most of the brushes I have are at their default but sometimes I change the settings to get them to work how I want them to.
PostPosted: Mon Oct 15, 2018 4:25 am  (#15)
Thank you so much Wallace for this nice brush pipe. A great job! :tyspin :cool
PostPosted: Mon Oct 15, 2018 9:14 am  (#16)
I guess I am that transparent, aye, Pat? lololol
PostPosted: Mon Oct 15, 2018 10:18 pm  (#17)
We are creatures of habit, Lyle!
PostPosted: Mon Oct 15, 2018 10:37 pm  (#18)
Thank you Wallace
PostPosted: Tue Oct 16, 2018 1:42 pm  (#19)
sallyanne wrote:
Thank you Wallace
:grooving
