It is currently Mon Nov 23, 2026 12:00 pm
 Post subject: filter "map / spinning according to a map"
PostPosted: Fri Dec 28, 2018 9:41 am  (#1)
This filter:
The embossed object is not above the original object.
how to set so that it is automatically in the same position as the initial object, because too long to move pixel by pixel with the cursor "Offset Y"? :(
 Post subject: Re: filter "map / spinning according to a map"
PostPosted: Fri Dec 28, 2018 10:05 am  (#2)
Works okay for me.
Did you try to reset (reinitialiser) and select the aux input (Entrée Aux) again?
PostPosted: Fri Dec 28, 2018 10:25 am  (#3)
Nidhogg wrote:
Works okay for me.
Nidhogg Image
After reset,it's the same.
PostPosted: Fri Dec 28, 2018 10:44 am  (#4)
Do you have a selection active?
This is what I come up with when there is a selection active.
Go to selection/ none ... and it works … at least for me.
Regards
nelo
PostPosted: Fri Dec 28, 2018 10:54 am  (#5)
nelo Image
no selection and just 2 layers
PostPosted: Fri Dec 28, 2018 11:42 am  (#6)
The offset is because the layer (or a selection)used as the bump map is a different size to the layer that is bump mapped.
example - two layers the X for the bump map smaller than the canvas
Apply a bump map and the X is set top-left-corner (offset X / Y = 0)
To keep it in position:
Either apply an offset (which you do not want to do ;) )
or more usually resize the bump map layer to the same size as the bumped layer.
PostPosted: Fri Dec 28, 2018 12:18 pm  (#7)
Go to Layer > Layer to image size and apply it in both layers (the bumpmap layer and the layer receiving the bumpmap).
This should fix the problem; As rich2005 said, the offset is caused because the filters take input from the individual layers and not the whole image.
PostPosted: Fri Dec 28, 2018 1:07 pm  (#8)
rich2005 Image and Dionisio Image
that's it :bigthup :bigthup :bigthup :bigthup
