It is currently Sun Nov 22, 2026 11:01 pm
 Post subject: GIMP 3.0 non-destructive editing does not support all filters
PostPosted: Fri Jan 24, 2025 3:11 am  (#1)
In this Photoshop tutorial
Photoshop Game-Changer! GRAIN SHADED GRADIENT MAPS
This was done with GIMP 2.10.38
It needs to merge the layers before applying the filter
But its final effect depends on some adjustments, so it may require frequent use UnDo.
So I tried using GIMP 3.0 instead.
But in the last step Gradient Map, I got this
It's so frustrating
Sorry for my poor English, I use Google Translate.
There may be something wrong, Please understand.
GIMP 2.10.38 rev1 portable+GAP+G'MIC+nufraw+Beautify+MathMap+...
 Post subject: Re: GIMP 3.0 non-destructive editing does not support all filters
PostPosted: Fri Jan 24, 2025 4:13 am  (#2)
It'll work one day. I'm sure about it.
NDE is just at the beginning. Let's be grateful for its implementation so far.
Originally, it wasn't even planned for 3.0.
So let's just be patient.
And if it's too frustrating - you can always pay for PS, can't you?
PostPosted: Fri Jan 24, 2025 4:20 am  (#3)
I noticed that your opacity level in 2.10 was set at 100. Maybe turn that down a bit?
PostPosted: Fri Jan 24, 2025 5:09 am  (#4)
At the moment, NDE only supports GEGL filters. Gradient Map is a "legacy" plugin. You can see it better in Gimp 2.10 where the GEGL filters have a G against the menu entry. The G has been dropped in GIMP 3.0
Edit: Sorry I do not watch YT videos anymore, too many advertisements.
You will just have to find other ways: Here two NDE filters that are still editable + a gradient but that relies on a Layer Mode.
PostPosted: Fri Jan 24, 2025 6:11 am  (#5)
Thank you for your reminder
I find Gradient Map in GEGL operation
And I use Firefox+AdBlock to watch YT videos, it block any advertisements
PostPosted: Fri Jan 24, 2025 11:54 am  (#6)
It's so frustrating
There has been a discussion about the "Merge" choice of filters, and it has been pointed out that some filters, having no dialog, don't give the choice.
PostPosted: Sat Jan 25, 2025 2:59 am  (#7)
It's so frustrating
I think if the official version(final release) cannot replace those unsupported filters, it would be better to have a clear label to explain it.
Why do you mention PS?
I'm a programmer, not an artist, and I'm retired too.
Using GIMP is purely to get more people to use free software.
If it's really depressing, then I'll just stop using any image processing software, that's it.
Besides, I have already made it with GIMP 2.10.38
If GIMP 3.0 RC2 disappoints me, Then I'll just stick with 2.10, Isn't it?
PostPosted: Sat Jan 25, 2025 3:18 am  (#8)
You are using a "Release candidate", which means things aren't finished yet.
Don't throw the baby with the bath water.
PostPosted: Sat Jan 25, 2025 3:49 am  (#9)
Dont throw the baby out with the bath water. I wonder where that thought came from. Who would discard a baby?
PostPosted: Sat Jan 25, 2025 10:41 am  (#10)
The challenge is how to do this without negatively impacting people's workflows. For instance, if Invert is automatically applied non-destructively, then people will wonder what their brush color is inverted (and they'll have to do extra steps to merge it down each time).
One idea would be to make a separate GUI-based version of those filters (like a dialogue that lets you choose which type of Invert to apply) so people could choose either the destructive or non-destructive version based on their needs. Still needs more design and testing though.
PostPosted: Sat Jan 25, 2025 2:19 pm  (#11)
I could easily make an invert filter with a GUI that has all 3 inverts in a drop down list.
PostPosted: Thu Apr 17, 2025 5:37 pm  (#12)
Hello, can I ask you where can I find the Gradient Map in GEGL Operation ?
because the (Colors > Map > Gradient Map) gives me the same problem as yours!
PostPosted: Thu Apr 17, 2025 8:48 pm  (#13)
gegl-workshop.dll was provided by GIMP 3.0 RC1, but has been removed since RC2
You can copy this file from RC1 yourself, or if you feel more confident you can download the file I attached.
Put the file into the xxxxxxxx\GIMP 3\lib\gegl-0.4 folder
File comment: Gradient Map in GEGL operation(from RC1)
gegl-workshop.zip [53.12 KiB]
Downloaded 1242 times
PostPosted: Sat Apr 19, 2025 2:53 pm  (#14)
JamesH, I already solved that problem and don't recommend your method.
You can download gradient map and all other hidden native GEGL filters here as plugins.
https://github.com/LinuxBeaver/GEGL-GIM ... s/releases
Its a lot safer then that .dll modification trick. Because they are installing as a GEGL plugin
PostPosted: Mon Apr 21, 2025 6:35 am  (#15)
thank you both so much for your help, I really appreciate it!
from what I've noticed in this plugin I can add up to 5 colors to it right ? so it can generate a gradient map of up to a 5-colored-gradient no more. right ?
PostPosted: Wed Apr 23, 2025 1:24 am  (#16)
Yes, here is a example
PostPosted: Fri Apr 25, 2025 12:20 pm  (#17)
exactly! thanks a lot for your help.
PostPosted: Wed Oct 28, 2026 2:35 pm  (#18)
Hello everyone!
Gradient Map from this link that previously worked for me with GIMP 3.0 doesn't appear in GIMP 3.2 !
is there an updated version that works in windows with GIMP 3.2.6 ?
PostPosted: Sun Nov 01, 2026 2:23 am  (#19)
CAn someone confirm if these work on GIMP 3.26?
PostPosted: Sun Nov 01, 2026 8:11 am  (#20)
They work for me in Windows 10 64 bit.
