It is currently Mon Nov 23, 2026 4:27 am
 Post subject: Heal Selection" fails with Lasso Tool
PostPosted: Fri Oct 17, 2025 6:39 pm  (#1)
Hello everyone!
I'd like to share a solution to a problem I had today: the "Heal Selection" filter (from the Resynthesizer plugin) suddenly stopped working.
After trying everything — reinstalling the plugin (both by copying its folder directly into the GIMP plugins directory and by installing it through the terminal via Flatpak) and even completely reinstalling GIMP — I discovered the problem wasn't the plugin, but the selection tool I was using.
"Heal Selection" wasn't working when I used the Free Select Tool (Lasso). However, when I tested it with the Ellipse Select Tool and the Paths Tool, it worked perfectly.
So, here's a tip for anyone facing the same issue: before you reinstall everything, try using a different selection tool first!
When trying to use heal selection with the lasso tool, it gave the messages below
By the way, does anyone have a technical explanation for why this might have happened? Why would the filter work with some selection tools but not specifically with the Lasso?
 Post subject: Re: Heal Selection" fails with Lasso Tool
PostPosted: Sat Oct 18, 2025 1:35 am  (#2)
I've seen that it won't work when the feathering option is active. Disable that - and it works.
