It is currently Thu Aug 20, 2026 10:45 am
 Post subject: I'm colourful & a gimp curious/enthusiast person from UK
PostPosted: Fri Feb 14, 2014 5:05 am  (#1)
Hi Gimpchat members!!! Love to be a part of a gimp community...never knew this chat forum existed till today :)
When I discovered gimp, I felt like this :gimp
I design various things on it for fun & for my friends. I have been creating designs and now I decide to print it for size 1mx1m. The printing company adviced that they want 300 dpi in tiff file. I tried various sites to find out the answer to create 300dpi image file but still confused as none of them tell you the right answer.
My question is how do I create an image that can be (printed 1mx1m) 300 dpi quality. I see pixels/inch & pixels all over. Please ignore my ignorance in dpi & ppi. I know its dots/inch & pixels/inch.
So, when I create new image, what should I put in image size (width & height) and pixels/inches etc on the drop down. Also, what should I put at the X & Y resolutions. I'm stuck :(
Help! help! Please :) Thankssssssssssssssssssssssssssssssssssssssssss a ton!
 Post subject: Re: I'm colourful & a gimp curious/enthusiast person from UK
PostPosted: Fri Feb 14, 2014 5:34 am  (#2)
1m = 39.37 inches
39.37 inches at 300 dots per inch = 39.37 * 300 = 11811 dots/pixels
So you would need to create an image 11811 x 11811 pixels to get 300dpi for a printed image 1m square.
And welcome from my corner of the soggy UK
Kevin
PostPosted: Fri Feb 14, 2014 5:49 am  (#3)
paynekj wrote:
1m = 39.37 inches
Kevin
Thanks Kevin. :)
So, I'm putting 11811x11811 pixels or 1m x 1m for width & height.
What should I select for X & Y resolution (pixels/inch)? 300 pixels/inch? Thanks :)
Hope u keepin safe this crazy weather! :)
PostPosted: Fri Feb 14, 2014 8:59 am  (#4)
PostPosted: Fri Feb 14, 2014 12:04 pm  (#5)
gimplover: welcome to gimp chat :)! wow, that's an ambitious sounding project you're working on. i think my poor laptop would explode if i tried working on a canvas that big.
PostPosted: Fri Feb 14, 2014 12:44 pm  (#6)
gimplover wrote:
paynekj wrote:
1m = 39.37 inches
Kevin
Thanks Kevin. :)
Yes, 300 pixels/in. X & Y resolution must be equal.
In Gimp, File | New... (expand, Advanced Options)
Welcome to Gimp Chat, gimplover.
PostPosted: Fri Feb 14, 2014 12:47 pm  (#7)
Welcome to Gimp Chat gimplover. The UK is a bit squelchy underfoot at the moment huh?
PostPosted: Fri Feb 14, 2014 2:19 pm  (#8)
Welcome to GC! :3
PostPosted: Fri Feb 14, 2014 5:00 pm  (#9)
http://tonysteeleebw.deviantart.com/
PostPosted: Sat Feb 15, 2014 12:04 pm  (#10)
Welcome!
I just accidentally hosed up a whole graphic project because I did it at the correct DPI and somehow did not get the correct print sizes...so be very careful to check and recheck when you create (and add any new photos/images) that they are all 300 DPI and that the print size is also correct. Otherwise you might have an image that is supposed to print at 7.7X10.2 / 300 DPI that instead prints at 4X6...
But then again, I doubt anyone else could have such a problem as I...
Another tip, do a test print and be sure it is correct and looks the way you want. There is a PDF function that will break your large images up and print them on 8.5X11 that you can then tape together...but it would let you double check before you go spend a TON on a huge print. Just select the correct "page" of the pdf and print off what you need to make sure your image will print right.
Raising children and dairy goats in Missouri, doing art in between.
