PhotoComix wrote:
@Partha
why compile gmic if not to add directly at least in the portable version ?
2 reasons -
1. David does not provide the 64-bit version which has been the main reason why I started building Gimp in the first place and I wanted G'mic.
2. I don't know if everyone wants G'mic. So, giving them an option.
About gmic
1) you should remove a file( bashcompletation.exe)
I did - it's no longer in the 7z download from my website and in the case of the installer, it's put in the main bin directory and so it does not interfere with the plugins.
Oh well you may even keep the file but is for the command line version of gmic, and should not be included with the plugin
2)GMiC maximize button doesn't work with 2,7
Something like this? It works on my machine for 64-bit Gimp.
File comment: Gmic Maximized
Do you get an error or nothing happens?
The splashscreen is really cool and everything else seems working fine
Thanks PC and thanks for testing!
Partha
