It is currently Tue Aug 11, 2026 9:49 pm
 Post subject: GIMP 3.0.2 portable and Linux Mint
PostPosted: Mon Mar 31, 2025 2:20 pm  (#1)
GIMP Version: 2.10.38
Operating System: Windows
GIMP Experience: Basic Level
Hello
I installed samj's portable Gimp: [size=85]https://samjcreations.blogspot.com/2025/03/gimp-302-portable-gmic-qt-gimp-353.html[/size]
on my Windows 10 and I would like to install it on a PC with Linux Mint Cinnamon 22.1
Since I'm new to Linux, do I have to put it in a specific folder or can I put it in any folder?
 Post subject: Re: GIMP 3.0.2 portable and Linux Mint
PostPosted: Tue Apr 01, 2025 12:48 am  (#2)
AppImages are the equivalent of Windows portables.
There is an AppImage here but the consensus is it's too big. It contains debug files which it doesn't need to.
PostPosted: Tue Apr 01, 2025 2:32 am  (#3)
@level_0
You can try this one, https://www.gimp-forum.net/Thread-Gimp3 ... 8#pid43608 - If it works, great. If not then delete it .
You can put it in any folder, make sure it is executable and as an initial check run it in a terminal
./gimp_302_deb.AppImage
If that works then try and make a menu entry using the Mint tool Main Menu. - I know, not easy for a new linux user ;)
edit: Just as a hint for a new launcher in Mint 22
I have tried out, a bit, in kubuntu 24.04 & Mint 22 also kubuntu 22.04 (all a bit flakey but working)
https://u.pcloud.link/publink/show?code ... i4AR53vY70 about 95 MB
Includes gmic_gimp_qt 3.5.3 / resynthesizer + heal plugins / FFT Remember - for gmic you need QT5 installed
@Tasmania
There is a note in the gimp log. The debug files will be gone in Gimp 2.0.4 AppImage
PostPosted: Tue Apr 01, 2025 2:44 am  (#4)
Thanks rich. I just found the Artbox AppImage which is at 3.03 and down to 162Mb.
Its the first Download link on the page :)
PostPosted: Tue Apr 01, 2025 2:55 am  (#5)
Yes, I saw that. I did do my own thing, unpacked the appimage, deleted all the *.debug files (300-and something), then repacked the appimage.
The gimp.org log is here: https://github.com/GNOME/gimp/commit/87 ... 91051cc656
PostPosted: Thu Apr 03, 2025 1:36 pm  (#6)
Thanks Tas_mania and rich2005
I'll leave the one on Linux Mint and use samj's Gimp on Windows 10. ;)
