It is currently Thu Aug 20, 2026 5:00 am
 Post subject: plasma-2 in Linux-Fedora [Solved] thanks Tux
PostPosted: Sun Nov 30, 2014 7:12 pm  (#1)
I downloaded plasma2 and put it in my user Plug-ins folder and yes it has permissions checked. Does anyone know why it isn't showing up under Render? thanks.
I have it installed in my windows7 and works okay there
 Post subject: Re: plasma-2 in Linux-Fedora
PostPosted: Sun Nov 30, 2014 7:16 pm  (#2)
Which version did you install? Link?
PostPosted: Sun Nov 30, 2014 7:26 pm  (#3)
I don't know where I got it. I just googled it and I saw PC one for Windows but not sure where I got this one,
EDIT: I now tried this one and it doesn't work for me.
viewtopic.php?p=4677#p4677
plasma2.zip [27.74 KiB]
Downloaded 141 times
PostPosted: Sun Nov 30, 2014 7:49 pm  (#4)
I compiled it for Linux_x64 using Fedora. Extract the binary into your plug-ins folder and start GIMP. I have also attached the source code for those who might need to compile for a different OS.
Shows up under Filters/Renders/Clouds/Plasma2
File comment: Plasma 2.11 Source Code
plasma2-2.11.tar.bz2 [20.21 KiB]
Downloaded 137 times
File comment: Plasma 2 For Linux-x64 (Binary)
plasma2-Linux_x64.zip [14.73 KiB]
Downloaded 153 times
PostPosted: Sun Nov 30, 2014 8:00 pm  (#5)
:pengy :pengy Thanks so much Tux. you are a wizard.
