It is currently Thu Aug 27, 2026 9:21 pm
 Post subject: Simplify Plug-in
PostPosted: Sat May 04, 2019 9:06 pm  (#1)
Above used version 2 of plug-in.
I don't know what to call it other than simplify because it reduces to specified number of colors and does a simpler vectorized version of image.
More details here -> https://gimplearn.net/viewtopic.php?f=3 ... 987#p25987
TinT
 Post subject: Re: Simplify Plug-in
PostPosted: Sun May 05, 2019 6:00 am  (#2)
Hi TIN.
And again, I like Your plugin.
For me it's Pseudo-Trace (potrace).
Pseudo - because there are no paths (but maybe you can add as options?)
Thank You.
PostPosted: Sun May 05, 2019 9:23 am  (#3)
Thanks for trying out plug-in.
Check version 3 (which create paths of colorfills).
TinT
PostPosted: Sun May 05, 2019 10:52 am  (#4)
TinT
PostPosted: Sun May 05, 2019 1:51 pm  (#5)
Thank You very much for the quick implementation of my request :hi5 - now it's time for many attempts to use it...
PostPosted: Sun May 05, 2019 2:07 pm  (#6)
Nice job, thank you! This is cool for pop art images.
Created newsprint halftone from cartoonized bw version of the same original that was used for simplify and pasted it over the result, soft light blending mode.
PostPosted: Sun May 05, 2019 10:02 pm  (#7)
Nice result!
TinT
PostPosted: Mon May 06, 2019 7:10 am  (#8)
Yeah i really like that also. :) :kpix :bigthup
PostPosted: Mon May 06, 2019 12:05 pm  (#9)
Thank you for compliments, had another go that I liked. I'm going to play with this a lot!
She said I have to upload the full image because the halftone got muddy in the composition.
PostPosted: Mon May 06, 2019 12:20 pm  (#10)
glad you're having fun with it :D
TinT
PostPosted: Tue May 07, 2019 10:24 am  (#11)
I really do. :tyspin
