selenamh93 wrote:
Hi, I'm very new here. I am trying to install da big gimpin plugin on a Mac OS and am having issues with it. I have managed to find the plug-in folder when you go under "GIMP-2.10" ->Preferences -> Folders + -> Plug-ins and then choosing the pathway "/Users/Username/Library/Application Support/GIMP/2.10/plug-ins. However, when I go to that location in my finder there is not a "plug-ins" folder... Do I add a folder with that file name? If so, I still am unable to access the plug-in on GIMP after I've copied the plug-ins labeled "da_big_gimpin_script_v3 9.09.36 AM", "da_big_gimping_script 9.09.36 AM", and "da_big_gimping_script_2 9.09.36 AM". Is anyone able to help me?
I have written tutorials on how to do this and nothing has changed with it in recent years...follow Erisians first suggestion, or if you can see a small house in your side bar start there....in the last folder you will find folders to aadd most things such as brushes, scripts, py, gradients etc etc....once you have added you can refresh GIMP while it is open in brushes etc but best if you restart the GIMP and then go from there.
