It is currently Thu Aug 13, 2026 10:17 am
 Post subject: New GEGL Filter to make Action Lines. It does away with Lina Nova
PostPosted: Sat May 14, 2022 11:07 am  (#1)
GEGL can now do a effect similar to Line Nova. on Linux just put the .so files in /gegl-0.4/plug-ins on Windows you have to build until someone contribute's DLLs
https://github.com/LinuxBeaver/GEGL-Action-Lines
 Post subject: Re: New GEGL Filter to make Action Lines. It does away with Lina Nova
PostPosted: Sat May 14, 2022 11:19 am  (#2)
ohhhh... just added a suggestion about the minimum radius value for smaller images on your reddit (I hate reddit) post.
This as an example: https://i.imgur.com/QVp2y26.jpg r < 2000
PostPosted: Sat May 14, 2022 2:41 pm  (#3)
Version for Gimp-2.10.30 Win 64 Bit attached.
Place the file in Gegl plugins in a directory: ... \lib\gegl-0.4\ (contains 37 * .dll files)
In menu: Tools➤GEGL Operation➤Action-Lines
Edit: an out-of-date attachment has been removed.
PostPosted: Sat May 14, 2022 7:38 pm  (#4)
use layers
PostPosted: Sat Jul 02, 2022 10:35 am  (#5)
Action Lines got a quality update that replaces threshold-alpha with gegl:opacity. This makes the lines much smoother instead of having rough edges.
PostPosted: Sun Jul 03, 2022 6:36 am  (#6)
Update version for Gimp-2.10.30/32 Win 64 bit in attachment.
action-lines_Win64bit_update.zip [36.75 KiB]
Downloaded 137 times
