It is currently Wed Aug 12, 2026 10:27 pm
 Post subject: GEGL Edge Extract - Edge Neon's algorithm in transparent background
PostPosted: Tue May 17, 2022 11:39 am  (#1)
Unless I get help or learn more this is my final filter. There are things I know GEGL can do but I don't know how to make a GUI of it.
I hope everybody enjoyed my filters and I hope other GEGL authors show up and make a difference. There is a high chance that @MareroQ will chime in with a Windows build. So all you need to do is put the dll or .so files in /gegl-0.4/plug-ins
https://github.com/LinuxBeaver/gegl-edge-extract
 Post subject: Re: GEGL Edge Extract - Edge Neon's algorithm in transparent backgroun
PostPosted: Tue May 17, 2022 12:17 pm  (#2)
Version for Gimp-2.10.30 Win 64 Bit attached.
Place the file in Gegl plugins in a directory: ... \lib\gegl-0.4\
In menu Tools➤GEGL Operation➤Edge Extraction
Edit: an out-of-date attachment has been removed.
PostPosted: Tue May 17, 2022 2:50 pm  (#3)
I am experimenting with edge sobel and I realize it does a better job. there is a high chance I will swap edge-neon with edge-sobel.
Poor MareroQ will have to recompile for Windows.
PostPosted: Tue May 17, 2022 3:13 pm  (#4)
Okay the algorithm has been swapped with edge sobel. This made a considerable difference in quality. If I knew more I could include all five edge detection algorithms gimp has.
PostPosted: Tue May 17, 2022 4:39 pm  (#5)
The filter had an update that changed the algorithm.
PostPosted: Wed May 18, 2022 9:54 am  (#6)
Why don't other users who can compile it want to do it? :hoh
New version in attachment.
PostPosted: Wed May 18, 2022 4:17 pm  (#7)
Perhaps because we haven't any idea how to go about compiling it.
Maybe you could write a guide to compiling GEGL plugins, then maybe you'll get some assistance.
Kevin
PostPosted: Thu May 19, 2022 2:03 am  (#8)
Hi Kevin.
The question was for those who can (i know how), but do not want to be active. :hehe
I do not want to persuade anyone to publish - I am only interested in the reason for such a decision (I know, but only for myself :mrgreen: ).
Sufficient information for compilation is provided in the file source link.
PostPosted: Wed Jul 06, 2022 11:13 pm  (#9)
Filter got an update and now has a blur that goes up to 6.5 (originally it stopped at 3) and it can change line colors. This goes good with blend modes like softlight and hslcolor.
PostPosted: Fri Jul 08, 2022 8:49 am  (#10)
Update version for Gimp-2.10.30/32 Win 64 bit in attachment.
edgeextract_Win64bit_update.zip [35.85 KiB]
Downloaded 68 times
