It is currently Wed Nov 25, 2026 5:40 pm
 Post subject: String Art Plug-in
PostPosted: Sat Dec 09, 2023 4:41 pm  (#1)
#!/usr/bin/env python
# thread-weave.py
# Author: Tin Tran
# String art, anyone? I thought it would be cool.
# Comment or questions gimpchat.com or gimp-forum.net
# Open source whatever the GIMP's license is.
from gimpfu import *
def string_art(img,layer,points,pattern):
    points = int(points) #make sure it's int
    pattern = [int(x) for x in pattern.split(',')] #make it array of ints
    vectors = pdb.gimp_image_get_active_vectors(img)
    num_strokes,stroke_ids = pdb.gimp_vectors_get_strokes(vectors)
    length = pdb.gimp_vectors_stroke_get_length(vectors,stroke_ids[0],0.1)
    sectionlength = length*1.0/points
    p = []
    #get all the points coordinates into p array
    for i in range(0,points):
        dist = sectionlength*i
        x,y,slope,valid = pdb.gimp_vectors_stroke_get_point_at_dist(vectors,stroke_ids[0],dist,0.1)
        p.append([x,y])
    cp = [] #control points
    checkpattern = [];
    currentpoint = 0;
    cp.append(currentpoint)
    firsttime=1;
    while 1==1: #loop until we break from it
        for i in range(0,len(pattern)):
            currentpoint = ((currentpoint + points) + pattern[i] ) % points;
        if (firsttime==1):
            checkpattern = cp[:] #copy this initial pattern to know when to stop
            firsttime = 0
        else:
            good = 1
            l = len(checkpattern)
            for j in range(0,l):
                if (cp[len(cp)-l+j]!=checkpattern[j]):
                    good = 0
                    break;
            if good==1: #it's all the same as checkpattern so we've done looping
                cp = cp[0:-(l-1)]
                break
    #here we have cp containing all our points index now create the path
    new_vectors = pdb.gimp_vectors_new(img,"String Art")
    pdb.gimp_image_insert_vectors(img,new_vectors,None,0)
    cpoints = []
    for i in range(0,len(cp)):
        cpoints = cpoints + (p[cp[i]]*3) #add 3 times the current point
    npoints = len(cpoints)
    stroke_id = pdb.gimp_vectors_stroke_new_from_points(new_vectors,0,npoints,cpoints,FALSE)
register(
    "python_fu_string_art",
    "Create String Art from Active Path",
    "TT",
    "TT",
    "2023.12.09",
    "A String Art...",
    "RGB*",      # Alternately use RGB, RGB*, GRAY*, INDEXED etc.
    #INPUT BEGINS
    (PF_IMAGE, "img", "Image", None),
    (PF_DRAWABLE,   "layer", "Drawable", None),
    (PF_INT, "points", "Points on Path:", 18),
    (PF_STRING, "stringpattern", "String Pattern (ie. 3,-2 means forward 3, backward 2...):", "3,-2"),  # alias PF_VALUE
    #INPUT ENDS
    string_art,
    menu="<Image>/Python-Fu")
main()
# Below is all the example input types for INPUTS for the plug-in which can be cut and pasted into #INPUT BEGINS section and edited to taste
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
This plug-in expects you to have an active path.
It'll then divide that path into equal-distance sections based on path length to get points.
And then uses your entered string pattern to move forward/backward on the points like string weaving or string art.
The result is a path, so you'll have to stroke it or whatever else you need to do to decorate your string art.
Demo video: https://www.youtube.com/watch?v=USnzjegjK-4
 Post subject: Re: String Art Plug-in
PostPosted: Sat Dec 09, 2023 6:09 pm  (#2)
This is really fast so it's a good candidate for Live Preview
here's code for live preview version
#grow-shrink-live.py
# Creator: TT
# This should allow user to adjust grow/shrink current selection with live preview
# Open Source
import gtk
# Global variables to store the parameters used for our effect/work to show preview or actual layer when user OK it
global_param1 = 0 #in this example it's shrinkgrow radius
global_param2 = 0   #in this example it's feather_radius
global_param3 = 10  #in this example it's iterations
global_param4 = 0   #in this example it's enhance_shadows
chosen_color = 0
sample_integer = 18
pattern_ = "3,-2"
image = 0 #we'll set these when dialog() is called so that we can access them later
drawable = 0
has_preview = False
preview_layer = 0
#for this operation
selection_channel = 0
proceed_with_changes = False
def apply_effect(layer): #function to do work on either preview layer or actual drawable when user clicks OK
    global preview_layer,has_preview
    if has_preview == True:
        pdb.gimp_image_remove_vectors(image,preview_layer)
        has_preview = False
        points = int(sample_integer) #make sure it's int
        pattern = [int(x) for x in pattern_.split(',')] #make it array of ints
        vectors = pdb.gimp_image_get_active_vectors(image)
        p = []
            p.append([x,y])
        checkpattern = [];
        currentpoint = 0;
        firsttime=1;
            if (firsttime==1):
                firsttime = 0
            else:
                good = 1
                        good = 0
                        break;
                    cp = cp[0:-(l-1)]
                    break
        new_vectors = pdb.gimp_vectors_new(image,"String Art")
        pdb.gimp_image_insert_vectors(image,new_vectors,None,0)
        cpoints = []
        pdb.gimp_item_set_visible(new_vectors,TRUE)
        preview_layer = new_vectors
        has_preview = True
    # global image
    # radius = global_param1
    # feather_radius = global_param2
    # pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,selection_channel) #first we selected the original saved channel
    # if radius < 0:
    #     pdb.gimp_selection_shrink(image,-radius)
    # else:
    #     pdb.gimp_selection_grow(image,radius)
    # pdb.gimp_selection_feather(image,feather_radius)
    # #do something to it to show it's effect so that user can distinguish between selected area or not
    # pdb.gimp_drawable_edit_fill(layer,FILL_FOREGROUND)
    # #pdb.gimp_ellipse_select(image,image.width/2-width/2,image.height/2-height/2,width,height,CHANNEL_OP_REPLACE,TRUE,FALSE,0)
    # #pdb.gimp_drawable_invert(layer,TRUE)
    # #pdb.gimp_selection_none(image)
    # gimp.displays_flush()
def apply_final(layer): #wrapper to apply effect on final and remove preview_layer meant to be called by on_ok_button_clicked
    pass
    # global preview_layer
    # #pdb.gimp_image_undo_group_start(image) #so it's undone in Ctrl+Z
    # pdb.gimp_image_undo_enable(image) #so that user can undo this next step
    # apply_effect(preview_layer)
    # #pdb.gimp_image_undo_group_end(image)
    # if has_preview:
    #     pdb.gimp_image_remove_channel(image,selection_channel) #so that we don't leave a saved channel laying around
    #     pdb.gimp_image_remove_layer(image,preview_layer)
    # pdb.gimp_image_set_active_layer(image,drawable)
    # pdb.gimp_context_set_foreground(save_foreground)
# Function to update the live preview
def update_live_preview(): #this is called everytime some parameter changes
    global global_param1, global_param2, global_param3, global_param4
    global image,drawable
    global has_preview,preview_layer #deal with preview layer
    # global selection_channel #this will save our current selection
    # Apply your plugin's effect using the current parameters
    # Use global_param1 and global_param2 to access the user's inputs
    if not has_preview: #create a preview layer
        # #pdb.gimp_message("Creating preview")
        # preview_layer = pdb.gimp_layer_new(image,image.width,image.height,RGBA_IMAGE,"preview",70,LAYER_MODE_NORMAL)
        # pdb.gimp_image_insert_layer(image,preview_layer,None,0) #insert top most so we see it
        # non_empty,x1,y1,x2,y2 = pdb.gimp_selection_bounds(image)
        # if non_empty == TRUE:
        #     pass #there's already a selection
        # else:
        #     pdb.gimp_selection_all(image) #if there's no selection we just select the whole image and work with that
        # selection_channel = pdb.gimp_selection_save(image)
        p = []
            p.append([x,y])
        checkpattern = [];
        currentpoint = 0;
        firsttime=1;
            if (firsttime==1):
                firsttime = 0
            else:
                good = 1
                        good = 0
                        break;
                    cp = cp[0:-(l-1)]
                    break
        cpoints = []
        has_preview = True #now set it true so we can deal with existing layer in later calls
    else: # already have preview layer
        pass
        #pdb.gimp_message("Removing existing and creating new Preview")
        # pdb.gimp_image_remove_layer(image,preview_layer) #remove it to create a new one to work on
        # preview_layer = pdb.gimp_layer_new(image,image.width,image.height,RGBA_IMAGE,"preview",50,LAYER_MODE_NORMAL)
    # pdb.gimp_image_set_active_layer(image,preview_layer)
    #debug message
    #pdb.gimp_message(str(global_param1)+","+str(global_param2)+","+str(global_param3)+","+str(global_param4))
    # Update the live preview layer with the modified image
save_foreground = 0
hilightcolor = (255,0,0)
def dialog(image_, drawable_):
    global image, drawable, save_foreground
    #if chosen_color==0:
    #   global chosen_color
    #  chosen_color = (0, 128, 255)  # Set default color
    #save these for updates
    image = image_
    #pdb.gimp_image_undo_disable(image) #for speed and also when user undo it doesn't see our preview creations/deletions
    #drawable = drawable_
    #save_foreground = pdb.gimp_context_get_foreground()
    #pdb.gimp_context_set_foreground(hilightcolor)
    dialog = gtk.Dialog("String-Art Live Preview", None, gtk.DIALOG_MODAL | gtk.DIALOG_DESTROY_WITH_PARENT)
    dialog.set_default_size(600, 100)
    #color_selection.ok_button.connect("clicked", on_color_ok_button_clicked)
    # Create an HBox to hold the label and slider -------------------------------------------------------------
    # hbox = gtk.HBox()
    # dialog.vbox.pack_start(hbox, expand=True, fill=True)
    # # Create a label on the left-hand side
    # label1 = gtk.Label("Shrink/Grow Radius:")
    # hbox.pack_start(label1, expand=False, fill=False, padding=5)
    # # Create an adjustment for the HScale (slider) with a range from 10 to 90
    # adjustment1 = gtk.Adjustment(value=0, lower=-400, upper=400, step_incr=1, page_incr=0)
    # param1_scale = gtk.HScale(adjustment=adjustment1)
    # param1_scale.set_digits(0)  # Display only integers
    # hbox.pack_start(param1_scale, expand=True, fill=True, padding=5)
    # # Connect callback functions for user interaction
    # param1_scale.connect("value-changed", on_param1_changed)
    # # # Create an HBox to hold the label and slider -------------------------------------------------------------
    # hbox2 = gtk.HBox()
    # dialog.vbox.pack_start(hbox2, expand=True, fill=True)
    # label2 = gtk.Label("Feather Radius:")
    # hbox2.pack_start(label2, expand=False, fill=False, padding=5)
    # adjustment2 = gtk.Adjustment(value=0, lower=0, upper=400, step_incr=1, page_incr=0)
    # param2_scale = gtk.HScale(adjustment=adjustment2)
    # param2_scale.set_digits(0)  # Display only integers
    # hbox2.pack_start(param2_scale, expand=True, fill=True, padding=5)
    # param2_scale.connect("value-changed", on_param2_changed)
    # # Create an HBox to hold the label and integer/float input box =====================================================
    hbox4 = gtk.HBox()
    dialog.vbox.pack_start(hbox4, expand=True, fill=True)
    # Create a label for the integer input
    label4 = gtk.Label("Points on Paths:")
    hbox4.pack_start(label4, expand=False, fill=False, padding=5)
    # Create a text entry for the integer input
    entry4 = gtk.Entry()
    entry4.set_text(str(sample_integer))
    entry4.set_width_chars(5)  # Adjust the width of input box as needed
    entry4.connect("changed", on_sample_integer_changed)
    hbox4.pack_start(entry4, expand=False, fill=False, padding=5)
    hbox5 = gtk.HBox()
    dialog.vbox.pack_start(hbox5, expand=True, fill=True)
    label5 = gtk.Label("String Pattern (ie 3,-2 means forward 3 points and backward 2 points:")
    hbox5.pack_start(label5, expand=False, fill=False, padding=5)
    entry5 = gtk.Entry()
    entry5.set_text("3,-2")
    entry5.set_width_chars(20)  # Adjust the width of input box as needed
    entry5.connect("changed", on_pattern_changed)
    hbox5.pack_start(entry5, expand=False, fill=False, padding=5)
    # Create an HBox to hold the label and color picker button =================
    # hbox5 = gtk.HBox()
    # dialog.vbox.pack_start(hbox5, expand=True, fill=True)
    # # Create a label for the color picker
    # label5 = gtk.Label("Color Picker:")
    # hbox5.pack_start(label5, expand=False, fill=False, padding=5)
    # # Create a color picker button
    # color_button = gtk.ColorButton()
    # color_button.set_use_alpha(False)  # Set to True if you want to include alpha channel
    # #default_color = gtk.gdk.Color(65535, 0, 0)  # Red in RGB, where values are between 0 and 65535
    # pdb.gimp_message("set:" + str(chosen_color[0]))
    # color_button.set_color(gtk.gdk.Color(chosen_color[0]*256, chosen_color[1]*256, chosen_color[2]*256))
    # color_button.connect("color-set", on_color_changed)
    # hbox5.pack_start(color_button, expand=False, fill=False, padding=5)
    # #toggle button ==============
    # hbox6 = gtk.HBox()
    # dialog.vbox.pack_start(hbox6, expand=True, fill=True)
    # label6 = gtk.Label("Sample Toggle:")
    # hbox6.pack_start(label6, expand=False, fill=False, padding=5)
    # toggle_button = gtk.ToggleButton()
    # # Set initial label
    # update_toggle_button_label(toggle_button)
    # # Connect the toggle event
    # toggle_button.connect("toggled", on_toggle_button_toggled)
    # hbox6.pack_start(toggle_button, expand=False, fill=False, padding=5)
    # #Combo box ===================================
    # hbox7 = gtk.HBox()
    # dialog.vbox.pack_start(hbox7, expand=True, fill=True)
    # label7 = gtk.Label("Sample Choice:")
    # hbox7.pack_start(label7, expand=False, fill=False, padding=5)
    # # Create a ComboBox
    # combo_box = gtk.ComboBox()
    # hbox7.pack_start(combo_box, expand=False, fill=False, padding=5)
    # # Create a ListStore model for ComboBox
    # list_store = gtk.ListStore(str)
    # options = ["Option 1", "Option 2", "Option 3"]  # Add your options here
    # for option in options:
    #     list_store.append([option])
    # # Set the model for ComboBox
    # combo_box.set_model(list_store)
    # # Create a CellRendererText to render the text in the ComboBox
    # cell_renderer = gtk.CellRendererText()
    # # Pack the CellRendererText into the ComboBox
    # combo_box.pack_start(cell_renderer, True)
    # combo_box.add_attribute(cell_renderer, 'text', 0)
    # # Set up the "changed" signal handler
    # combo_box.connect("changed", on_combobox_changed)
    # # Set the default option to "Option 1" ======================================
    # default_option = "Option 1"
    # default_iter = list_store.get_iter_first()
    # while default_iter is not None:
    #     if list_store.get_value(default_iter, 0) == default_option:
    #         combo_box.set_active_iter(default_iter)
    #         break
    #     default_iter = list_store.iter_next(default_iter)
#     color_selection.show_all()
#     color_selection = gtk.ColorSelectionDialog("Select Color")
#     # Run the dialog
#     response = color_selection.run()
#     # Connect the "clicked" signal after the dialog has been shown
#     color_selection.ok_button.connect("clicked", on_color_ok_button_clicked)
# # Check the response and destroy the dialog
#     if response == gtk.RESPONSE_OK:
#         on_color_ok_button_clicked(color_selection)
#     else:
#         color_selection.destroy()
    # hbox3 = gtk.HBox()
    # dialog.vbox.pack_start(hbox3, expand=True, fill=True)
    # label3 = gtk.Label("iterations:")
    # hbox3.pack_start(label3, expand=False, fill=False, padding=5)
    # adjustment3 = gtk.Adjustment(value=10, lower=1, upper=30, step_incr=1, page_incr=0)
    # param3_scale = gtk.HScale(adjustment=adjustment3)
    # param3_scale.set_digits(0)  # Display only integers
    # hbox3.pack_start(param3_scale, expand=True, fill=True, padding=5)
    # param3_scale.connect("value-changed", on_param3_changed)
    # Add an OK button
    ok_button = dialog.add_button(gtk.STOCK_OK, gtk.RESPONSE_OK)
    ok_button.connect("clicked", on_ok_button_clicked)
    # Show the dialog
    dialog.show_all()
    update_live_preview() #call this once so we see effect
    dialog.run()
# def on_combobox_changed(combobox):
#     global selected_option
#     model = combobox.get_model()
#     active_iter = combobox.get_active_iter()
#     if active_iter:
#         selected_option = model.get_value(active_iter, 0)
#         pdb.gimp_message("Selected option:" + str(selected_option))
# def on_toggle_button_toggled(button):
#     global proceed_with_changes
#     proceed_with_changes = not proceed_with_changes
#     pdb.gimp_message("Sample toggle result:" + str(proceed_with_changes))
#     update_toggle_button_label(button)
# def update_toggle_button_label(button):
#     label = "Yes" if proceed_with_changes else "No"
#     button.set_label(label)
def on_sample_integer_changed(entry):
    global sample_integer
    try:
        sample_integer = float(entry.get_text()) #int(entry.get_text())
        #pdb.gimp_message(sample_integer)
    except ValueError:
        # Handle the case where the input is not a valid integer
        pass
def on_pattern_changed(entry):
    global pattern_
    try:
        pattern_ = str(entry.get_text()) #int(entry.get_text())
        #pdb.gimp_message(pattern_)
    except ValueError:
        pass
# #need these 2 functions for color picker(s)
# def on_color_changed(widget, data=None):
#     pdb.gimp_message("ran color")
#     color = widget.get_color()
#     chosen_color = (int(color.red/256), int(color.green/256), int(color.blue/256))
#     pdb.gimp_message(str(chosen_color[0]))
#     update_live_preview()
# def on_color_ok_button_clicked(dialog, data=None):
#     pdb.gimp_message("color clicked")
#     global selected_color
#     color = color_selection.get_current_color()
#     selected_color = (int(color.red * 255), int(color.green * 255), int(color.blue * 255))
#     pdb.gimp_message(selected_color[0])
#     dialog.destroy()
# Callback function for updating the live preview when param1 changes
# def on_param1_changed(scale):
#     global global_param1
#     global_param1 = scale.get_value()
# # Callback function for updating the live preview when param2 changes
# def on_param2_changed(scale):
#     global global_param2
#     global_param2 = scale.get_value()
# def on_param3_changed(scale):
#     global global_param3
#     global_param3 = scale.get_value()
# Callback function for the OK button
def on_ok_button_clicked(button, data=None):
    global drawable
    apply_final(preview_layer) #preview layer because we don't want to apply the invert to final layer it's just for viewing
    button.get_toplevel().destroy() #destroys the gtk dialog window
# Register the Python-Fu plugin
register(
    "python_fu_string_art_live",
    "Grow/Shrink Current Selection with Live Preview",
    "TT",
    "TT",
    "2023.12.09",
    "<Image>/Python-Fu/Live Preview/String Art Live",  # Menu location
    "*",  # Image type
    dialog
main()
PostPosted: Sat Dec 09, 2023 7:18 pm  (#3)
Which reminds me... there was a request I forgot from which user but it was related to created looms of different shapes to be weave and they just needed the ability in GIMP to draw those shapes which I wrote but it's lost on the old forum.
That was a fun thing to write I forgot the requirements for it now.
PostPosted: Sun Dec 10, 2023 6:02 am  (#4)
For circular loom designs: https://tinmantaken.blogspot.com/2023/1 ... signs.html
PostPosted: Tue Dec 12, 2023 12:23 am  (#5)
Thank you for the plug-in Tim :tyspin
I think it's one that invites experimentation with multiple runs so maybe it would be nice to put the number of points and string pattern in the new path's name and make it visible.
Here's an outcome I got:
PostPosted: Tue Dec 12, 2023 1:23 am  (#6)
Really cool, Tran. :)
PostPosted: Tue Dec 12, 2023 1:30 am  (#7)
Of course I had to droste the result. lol
PostPosted: Tue Dec 12, 2023 3:18 am  (#8)
OK; one more before I hit the sack. Call this one, Dream Weaver. :)
https://www.flickr.com/photos/163034485 ... 93/sizes/o
PostPosted: Tue Dec 12, 2023 1:32 pm  (#9)
Cool experiments peeps. Thanks for trying it out. :D
PostPosted: Wed Dec 13, 2023 2:02 am  (#10)
OK, Tran; call this one Quantum Entanglement. Used G'MIC's Conformal Mapping this time. :)
PostPosted: Thu Dec 14, 2023 5:33 am  (#11)
You'rs are awesome teapot. Can you give me your settings. I cann't get anywhere near there!
PostPosted: Thu Dec 14, 2023 5:37 am  (#12)
Cool Lyle
PostPosted: Thu Dec 14, 2023 10:34 am  (#13)
Lyle, Loving all your pipe cleaner outcomes :yes
In the first one, it's cool you made it look three dimensional with the back section darker. Just trying to figure out how you did it, was it make the front and back separately and then make the back darker?
Thank you sallyanne :tyspin
My settings were:
Image size 1000x1000.
Input path a circle of diameter 876
A string art plugin settings:
Points on path: 200
String pattern: 58,99,150
First image, stroke path:
Stroke line:
Solid colour
Antialiasing ticked
Line width 2
Second image, using the same path:
On a layer with a black background:
Path to selection.
Fill with white.
PostPosted: Thu Dec 14, 2023 7:15 pm  (#14)
Tim, thanks for the script! :cool
teapot, very nice! :)
Lyle, awesome work! :bigthup
Charles
PostPosted: Fri Dec 15, 2023 7:13 am  (#15)
Have experimented a little. Thanks for the plugin.
All the same but a little bit different
PostPosted: Fri Dec 15, 2023 11:02 pm  (#16)
Appreciate the comments.
To answer TP's query, it's not really that hard. I dup, rotate the top layer a bit so that the points divide the ones on the bottom layer (may 5 degrees tops but likely a lot less than that; eyeballed the operation). I then selected the transparent areas above and the center of the top layer and grow it a tad, click bottom layer and chose delete so the points of it won't show (just realized that I might not have had to do the center layer; lol), and then darken the bottom layer a tad (dupped the bottom layer and set the one above it to difference and adjusted opacity to taste) and voila. :)
edit:
Forgot to mention that Sallyanne made some really cool results. :)
PostPosted: Sat Dec 16, 2023 1:42 pm  (#17)
Lyle, Thank you for your explanation :coolthup
sallyanne, Looking good :kpix
PostPosted: Sat Dec 16, 2023 7:23 pm  (#18)
Is there a downloadable file available yet?
PostPosted: Sat Dec 16, 2023 11:26 pm  (#19)
stringartplugin byTin.7z
Thank you teapot and Lyle
@makenzieh, just copy one or both of the codes (separately) and paste them into a notepad (notepad++ is preferred but not necessary.) Save as a .py in your plugins folder.
I only did the first one. oh the codes are in the first couple of posts
PostPosted: Sun Dec 17, 2023 4:51 am  (#20)
You are on fire again Tim. Amazing outcomes by all thanks to you.
I wish I had had this one in 2018 when I did it all by hand...
and how it might look with your plug-in...
Perhaps I need to re-visit!
