It is currently Thu Nov 26, 2026 7:01 am
 Post subject: Distort with LIVE PREVIEW
PostPosted: Fri Jan 26, 2024 11:25 am  (#1)
New plugin based on: distress-selection.scm [Select/Distort...] & fuzzyborder.scm [Filters/Decor/Fuzzy Border...] by Chris Gutteridge & G'MIC-Qt Frame [Fuzzy] - but more possibilities...
Download from gimpscripts.net: Distress Live Preview
 Post subject: Re: Distort with LIVE PREVIEW
PostPosted: Sat Jan 27, 2024 9:50 am  (#2)
Thanks a lot MareroQ. It's brilliant! :hi5 :tyspin
PostPosted: Sat Jan 27, 2024 6:17 pm  (#3)
Thank you Isabella.
Tin Tran's live preview code really offers some great possibilities that neither G'MIC-Qt nor GEGL has (e.g. using paths or any PDB routine).
Version 2.0 with added shadow option is now available.
PostPosted: Sun Jan 28, 2024 5:12 am  (#4)
Great with shadow, too. Thank you so much. :coolthup :tyspin
PostPosted: Wed Feb 14, 2024 4:21 am  (#5)
Version 2.1 is available.
Change: Fixed a bug when an image has more than one layer. Now works for the active layer.
PostPosted: Tue Feb 20, 2024 10:40 am  (#6)
Last small update (Ver.2.2): added edge stroke option.
