It is currently Tue Nov 24, 2026 9:24 am
 Post subject: Watermark with Image or Text
PostPosted: Sat Nov 16, 2024 12:18 pm  (#1)
Ver.2.
Some of you may remember from gimp scripts net.
Here is the new version (slightly improved and expanded) for Gimp-2.10.xx.
In the Gimp menu:
Filters ➤ Decor ➤ Watermark with Image or Text...
MrQ Watermark_with_pattern.zip [9.16 KiB]
Downloaded 2991 times
 Post subject: Re: Watermark with Image or Text
PostPosted: Sat Nov 16, 2024 3:28 pm  (#2)
right on!
PostPosted: Sat Nov 16, 2024 3:32 pm  (#3)
Reason my watermark plug-in doesn't provide text is because I thought that any text designed can be saved as image since watermark is something that doesn't change too often. And because I didn't want to add too many options and I was lazy to do it full blown.
PostPosted: Sun Nov 17, 2024 12:21 am  (#4)
Hi Tim.
It's a good joke that you're lazy. :rofl
As for me, you're also very creative. :keybdtype
Despite the name, for me this plugin also makes it easier to do other text operations on photos, such as descriptions (place or date) and memes. :paint
And it's true - the picture avatar changes very rarely - but it's worth having it "at hand" without having to look for where I saved it.
Best regards. :wvy
PostPosted: Sun Nov 17, 2024 9:16 am  (#5)
Yeah definitely good to have as optional for other users.
PostPosted: Sun Nov 17, 2024 11:13 am  (#6)
Rel.3
Two small additions:
- BumpMap
- Rotate
Note to BumpMap: to avoid adding too many parameters, typical default values ​​were used. If the watermark color is solid black, the effect will not be visible.
MrQ Watermark_with_pattern Ver.3.zip [9.44 KiB]
Downloaded 2748 times
PostPosted: Tue Nov 19, 2024 5:59 am  (#7)
Rel.4.
Another two (last :hehe ) small additions:
- add Position: "CENTER-LEFT", "CENTER-RIGHT"
- Rotate Custom angle.
MrQ Watermark_with_pattern.zip [9.65 KiB]
Downloaded 2068 times
PostPosted: Mon Dec 02, 2024 2:06 pm  (#8)
Ver.5.
This version introduces another new option (the idea comes from Watermark BIMP: viewtopic.php?f=8&t=18341&p=260418#p260418) - scale loaded image.
It is more interesting if the download counter has been fixed? (which was reported but there was no feedback).
MrQ Watermark_with_pattern Ver.5.zip [9.78 KiB]
Downloaded 104 times
PostPosted: Fri Dec 06, 2024 6:19 am  (#9)
Ver.6
In this version, there are practically only three changes:
- any type of watermark can be scaled,
- multiple watermark positions can be selected,
- and of course the required changes in the GUI (which was an interesting challenge).
In Bimp you can only select one position.
In this plugin you can select from 0 (when you use "Fill") to 9 (all).
MrQ Watermark_with_pattern Ver.6.zip [10.19 KiB]
Downloaded 102 times
PostPosted: Fri Dec 06, 2024 8:47 pm  (#10)
Thank you for the update! :)
PostPosted: Sat Dec 07, 2024 6:03 am  (#11)
Ver. 6 U
This version only differs in adding Unicode symbols to the orientation (may display clutter on some Linux versions) and automatic text justification to the center (useful when text has several lines).
Tip:
A huge selection of UNICODE characters can be used for watermarking or meme.
A simple workflow example:
1. Launch your chosen Unicode plugin
viewtopic.php?f=9&t=17235&hilit=80_character_groups&start=20#p245641
Recommended Unicode_to_shape_80_character_groups.py by Skinnyhouse/MrQ in the attachment.
(in menu: Filters ➤ Unicode to shape ➤ UNICODE Character Groups...)
2. Copy the symbol name.
3. Paste as text
Unicode_to_shape_80_character_groups V.0.2.zip [8.78 KiB]
Downloaded 100 times
MrQ Watermark_with_pattern Ver.6 U.zip [10.3 KiB]
Downloaded 114 times
