It is currently Mon Nov 23, 2026 4:11 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2  Next
 Post subject: random dowtown
PostPosted: Thu Dec 12, 2024 2:58 pm  (#1)
Does anyone have random downton py.for me?
 Post subject: Re: random dowtown
PostPosted: Thu Dec 12, 2024 4:20 pm  (#2)
I found this but was unable to get a plugin.
viewtopic.php?f=9&t=16798#p230899
PostPosted: Thu Dec 12, 2024 5:36 pm  (#3)
Try this one.
random_downtown.zip [2.71 KiB]
Downloaded 85 times
PostPosted: Fri Dec 13, 2024 1:23 am  (#4)
GimpLearn scripts&plugins.zip [510.59 KiB]
Downloaded 110 times
Here are all the GimpLearn scripts-Plug-ins. Random-Downtown version 5 is included.
PostPosted: Fri Dec 13, 2024 1:59 am  (#5)
Thanks for sharing... but unfortunately it doesn't work for me anymore
PostPosted: Fri Dec 13, 2024 2:37 pm  (#6)
@Jappaloe63 - my apologies. I should have checked it out first; my version is release 5 and it does not work for me either. Perhaps Trandoductin could fix it up.
PostPosted: Fri Dec 13, 2024 5:20 pm  (#7)
Here's the fix for now
#!/usr/bin/env python
# random_downtown.py Rel 5
# Created by Tin Tran
# Comments directed to http://gimplearn.net
# License: GPLv3
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY# without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# To view a copy of the GNU General Public License
# visit: http://www.gnu.org/licenses/gpl.html
#| Change Log |
# Rel 1: Initial release.
# Rel 2: Try to bypass Certificate Verification Error repoted by Pat625.
# Rel 3: Filled windows.
# Rel 4: Make seamless (requested by lylejk on GIMPCHAT). You just gotta merge all the building layers and then "layer to image size".
# Rel 5: Run different code depending on version 2.8 or 2.10
from gimpfu import *
import random
import re, tempfile
import os
import ssl
#open and write tempf once so that it doesn't make multiple files in document history.
tempf=tempfile.NamedTemporaryFile(mode='w', suffix='.svg', dir=gimp.directory, delete=False)
tempf.write("whatever")
tempf.close()
import urllib2
import ssl
# Create an SSL context (similar to gcontext in Python 2)
# Fetch the file content
def python_random_downtown_tt(image, layer, minWidth, minHeight, maxWidth, maxHeight, numB):
   pdb.gimp_image_undo_group_start(image)
   pdb.gimp_context_push()
   gcontext = ssl._create_unverified_context()
   #gcontext = ssl.create_default_context()
   # gcontext = ssl.SSLContext(ssl.PROTOCOL_TLSv1)
   numB = int(numB)
   # gcontext = ssl.SSLContext(ssl.PROTOCOL_TLSv1)  # Only for gangstars to by pass certifate check found on https://stackoverflow.com/questions/27835619/urllib-and-ssl-certificate-verify-failed-error
   for i in range(0,numB):
      url = 'https://unsplash.it/1600/1200/?random'
      filecontent = urllib2.urlopen(url, context=gcontext).read()
      #filecontent = urllib.request.urlopen(url, context=gcontext).read()
      #filecontent = urllib2.urlopen('https://unsplash.it/1600/1200/?random', context=gcontext).read()
      f = open(tempf.name,"wb")
      f.write(filecontent)
      f.close();
      #urllib.urlretrieve("https://unsplash.it/1600/1200/?random",tempf.name)
      random_image = pdb.file_jpeg_load(tempf.name,tempf.name)
      random_layer = pdb.gimp_image_get_active_layer(random_image)
      #pdb.gimp_display_new(random_image)
      active_layer = pdb.gimp_image_get_active_layer(random_image)
      bwidth = random.randrange(minWidth,maxWidth+1) #building width random between min and max width
      bheight = random.randrange(minHeight,maxHeight+1) #building height random between min and max width
      x = random.randrange(0,1600-bwidth+1) #top left corner of building location x
      y = random.randrange(0,1200-bheight+1) #top left corner of building location y
      #copy step which creates building look
      pdb.gimp_image_select_rectangle(random_image,CHANNEL_OP_REPLACE,x,y,bwidth,bheight)
      btype = random.randrange(0,3)
      innerwidth = bwidth * 9.0/10.0
      innerheight = bheight * 9.0/10.0
      startx = (bwidth-innerwidth)/2.0
      starty = (bheight-innerheight)/2.0
      if btype == 0: #do horizontal windows
         num_rows = random.randrange(8,16)*4+3; #number of rows.
         row_height = innerheight*1.0/num_rows*4;
         win_height = innerheight*1.0/num_rows*3;
         for j in range(1,num_rows+1):
            if (j%4)==3: #if odd we deselect it
               wx = x+startx
               wy = y+starty + (j/4) * row_height
               pdb.gimp_image_select_rectangle(random_image,CHANNEL_OP_SUBTRACT,wx,wy,innerwidth,win_height)
      elif btype == 1: #do vertical windows
         num_cols = random.randrange(5,10)*4+3; #number of cols
         col_width = innerwidth*1.0/num_cols*4;
         win_width = innerwidth*1.0/num_cols*3;
         for k in range(1,num_cols+1):
            if (k%4)==3: #if odd we deselect it
               wx = x+startx + (k/4) * col_width
               wy = y+starty
               pdb.gimp_image_select_rectangle(random_image,CHANNEL_OP_SUBTRACT,wx,wy,win_width,innerheight)
      elif btype == 2: #do actual windows
         num_cols = random.randrange(5,10)*4+3; #number of cols.
                     pdb.gimp_image_select_rectangle(random_image,CHANNEL_OP_SUBTRACT,wx,wy,win_width,win_height)
      pdb.gimp_edit_copy(active_layer)
      floating_sel = pdb.gimp_edit_paste(layer,True)
      pdb.gimp_floating_sel_to_layer(floating_sel)
      y_offset = layer.height*2.0/3.0 - bheight
      x_offset = random.randrange(0,layer.width+1)
      pdb.gimp_layer_set_offsets(floating_sel,x_offset,y_offset)
      #create seamless
      gimp_version = pdb.gimp_version() #GET GIMP VERSION
      if x_offset > (layer.width - bwidth): #if it pops out on the right side.
         right_x_offset = x_offset - layer.width     #make a copy on the left side so that it's seamless
         pdb.gimp_layer_set_offsets(floating_sel,right_x_offset,y_offset)
         if gimp_version.startswith("2.8"):
            result = image.layers[0]
            result = pdb.gimp_image_merge_down(image,result,EXPAND_AS_NECESSARY)
      #do it again so it's filled windows.
         pdb.gimp_brightness_contrast(floating_sel,int(-0.45*127),0)
      elif gimp_version.startswith("2.10"):
         pdb.gimp_drawable_brightness_contrast(floating_sel,-0.45,0)
      #create seamless
      result = floating_sel
         pdb.gimp_image_lower_item(image,result)
      pdb.gimp_image_delete(random_image)
   #pdb.gimp_progress_init("Processing...",None)
   #pdb.gimp_progress_update(float(intensity)/255.0)
   pdb.gimp_context_pop()
   pdb.gimp_image_undo_group_end(image)
   pdb.gimp_displays_flush()
register(
   "python_fu_random_downtown_tt",
   "Creates Random Downtown Collage",
   "Tin Tran",
   "Tin Tran",
   "August 2018",
   "<Image>/Python-Fu/Random Downtown...",             #Menu path
   "RGB*, GRAY*",
   (PF_SPINNER, "minWidth", "Smallest Building Width:", 100, (10, 2000, 1)),
   (PF_SPINNER, "minHeight", "Smallest Building Height:", 200, (10, 2000, 1)),
   (PF_SPINNER, "maxWidth", "Largest Building Width:", 200, (10, 2000, 1)),
   (PF_SPINNER, "maxHeight", "Largest Building Height:", 400, (10, 2000, 1)),
   (PF_SPINNER, "numB", "Number of Buildings to Generate:", 20, (1, 500, 1)),
   #(PF_GRADIENT, "gradient", "Background Gradient:", 0),
   #(PF_TOGGLE, "reverse",   "Reverse Gradient:", 0),
   #(PF_SPINNER, "slice_angle", "Rotate angle(before slicing):", -5, (-180, 180, 1)),
   #(PF_SPINNER, "slice_shift", "Slice Shift(pixels):", -30, (-100, 100, 1)),
   #(PF_SPINNER, "text_angle", "Rotate angle(when complete):", -8, (-180, 180, 1)),
   python_random_downtown_tt)
main()
PostPosted: Fri Dec 13, 2024 9:17 pm  (#8)
I upgraded my version using the fix above. Ran the plugin with default values - all OK. But then ran it several times with changed parameters and it failed each time.
PostPosted: Sat Dec 14, 2024 2:14 am  (#9)
fix #2
# License: GPLv3
#| Change Log |
import random
import re, tempfile
import os
import ssl
tempf.close()
import urllib2
import ssl
links = ['https://plus.unsplash.com/premium_photo-1676218886284-bca308235404?q=80&w=1936&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1726725935085-fbc079dc5557?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1673621329410-e4ef5df05b69?q=80&w=1936&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1648714406165-bc37682149cb?q=80&w=1925&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649956736495-5685285a8f9f?q=80&w=2070&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1672663791479-c275b663fd72?q=80&w=1912&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1648618657670-d7d64c5e3ef7?q=80&w=2080&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1698849368937-37dddf9f58f1?q=80&w=1935&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1717489358244-01dd1c704afa?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1680143217012-db17c482ab94?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1673890318279-02d6cf905019?q=80&w=1936&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1678904817922-b20be9a075a8?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1685477990878-da34123f5998?q=80&w=2070&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649685819493-e5f3688a7d36?q=80&w=1991&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649372450315-7a69c613fb10?q=80&w=2071&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649972046682-2583cdd9bab8?q=80&w=1950&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1650060165632-82e4f0dacfc0?q=80&w=2112&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1676625176020-3bbb1c0adea1?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649289264155-4404150df2fb?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1647694079696-36fb2f5e337a?q=80&w=1936&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1680281937115-c5eca9c68cc1?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649384472975-98ac52a096d7?q=80&w=2127&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649372449815-306c7a9d715b?q=80&w=2018&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649232275731-108ab7eb2a44?q=80&w=1975&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1463130456064-77fda7f96d6b?q=80&w=2070&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1532456745301-b2c645d8b80d?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1649777689218-f5ddf4f69381?q=80&w=1972&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1483959651481-dc75b89291f1?q=80&w=2149&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1676269617127-24352e84349a?q=80&w=2070&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1451755032734-ada8d61ecf2f?q=80&w=2008&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1684311194610-1243fc49cfcb?q=80&w=1930&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1486718448742-163732cd1544?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1488972685288-c3fd157d7c7a?q=80&w=2070&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1494028960909-2321fad2a785?q=80&w=2080&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://plus.unsplash.com/premium_photo-1672265517508-52bbda78e263?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1527831176161-52b74dab16ea?q=80&w=1935&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D',
'https://images.unsplash.com/photo-1612365009551-0abb42a5f096?q=80&w=1974&auto=format&fit=crop&ixlib=rb-4.0.3&ixid=M3wxMjA3fDB8MHxwaG90by1wYWdlfHx8fGVufDB8fHx8fA%3D%3D'
   numB = int(numB)
      filecontent = urllib2.urlopen(links[random.randrange(0,len(links))], context=gcontext).read()
      f.close();
               wx = x+startx
               wy = y+starty
      #create seamless
      #create seamless
register(
   "Tin Tran",
   "Tin Tran",
   "August 2018",
   "RGB*, GRAY*",
main()
PostPosted: Sat Dec 14, 2024 2:23 am  (#10)
Ran the latest fix and it all seems OK now; thanks.
PostPosted: Sat Dec 14, 2024 2:46 am  (#11)
Fix #3, Doesn't use random image but GIMP Patterns textures (faster)
# License: GPLv3
#| Change Log |
import random
import re, tempfile
import os
import ssl
tempf.close()
import urllib2
import ssl
   #gcontext = ssl._create_unverified_context()
   numB = int(numB)
      #filecontent = urllib2.urlopen(links[random.randrange(0,len(links))], context=gcontext).read()
      #f = open(tempf.name,"wb")
      #f.write(filecontent)
      #f.close();
      iWidth = maxWidth
      iHeight = maxHeight
      random_image = pdb.gimp_image_new(iWidth,iHeight,RGB)
      random_layer = pdb.gimp_layer_new(random_image,iWidth,iHeight,RGBA_IMAGE,'randomlayer',100,LAYER_MODE_NORMAL)
      pdb.gimp_image_insert_layer(random_image,random_layer,None,0)
      num_patterns,pattern_list = pdb.gimp_patterns_get_list("")
      pdb.gimp_context_set_pattern(pattern_list[random.randrange(0,len(pattern_list)-1)+1]) #pick one but the first one
      pdb.gimp_edit_fill(random_layer,FILL_PATTERN)
      #random_layer = pdb.gimp_image_get_active_layer(random_image)
      x = random.randrange(0,iWidth-bwidth+1) #top left corner of building location x
      y = random.randrange(0,iHeight-bheight+1) #top left corner of building location y
               wx = x+startx
               wy = y+starty
      #fill it with something
      #create seamless
      pdb.gimp_selection_none(random_image)
      #create seamless
register(
   "Tin Tran",
   "Tin Tran",
   "August 2018",
   "RGB*, GRAY*",
main()
Sample creation using the above plug-in (that GIMP patterns textures) I just reflected it and changed opacity for fun
PostPosted: Sat Dec 14, 2024 4:12 am  (#12)
Thank you all!
PostPosted: Sun Dec 15, 2024 7:58 pm  (#13)
PostPosted: Mon Dec 16, 2024 3:20 am  (#14)
Works great in Gimp-2.10.38 RC1 Tran. Thanks for the update! :bigthup
Had to do the tsunami thing :lol
PostPosted: Mon Dec 16, 2024 8:13 am  (#15)
Gave it a try.
PostPosted: Mon Dec 16, 2024 8:30 am  (#16)
Tsunami and then dry version nice peeps!
PostPosted: Sun Feb 16, 2025 4:13 am  (#17)
Tran, I need some help with the random downtown plugin, if you have the time.
I am using Gimp 2.10.38 AppImage and Linux Mint 22.1. In the past, several years ago, I was able to successfully use your plugin. It has always been in my plugin folder and is set to "allow executing file as program". Upon seeing this thread, it reminded me of the plugin and I thought I would create another downtown image and that is where the problem began.
All my plugins like billboard sign, playing card, coin creator, sliced text, resynth, beautify and others work, except for random downtown. I've done a plugin search for it, etc... and can't find the entry in any of the menu lists, as if it doesn't exist even though it is in the correct plugin folder.
I also updated random_downtown_5 with the Fix #3 script you provided, no change.
What am I missing? Is there a step to take that I have forgotten about in order to be able to utilize this plugin?
PostPosted: Tue Feb 18, 2025 9:40 am  (#18)
did you make it executable? on Linux you have to set that.
PostPosted: Tue Feb 18, 2025 12:43 pm  (#19)
Yes, it's set to execute. It's really bizarre because all other plugins work, including several of yours. I've even put the .py file in a folder named Random Downtown, thinking that may help, along with just the file itself. So, at points, I've actually had two random downtown python files in the Plugins folder, trying anything combination to see if it would show up. I've re-downloaded it several times.
I'm using an AppImage 2.10.38 from Tasmania, I believe, where all the other plugins seem to work fine. I've tried several .py plugins over the last couple of days that I didn't want to use but just wanted to test to see if I could still add plugins and they worked also.
Is it named Random Downtown in the file menu, maybe I'm overlooking it that way. Do you have some older versions of it I may try because, as I said, it worked a few years ago. I don't know when it disappeared from the menu or when it quit working.
PostPosted: Tue Feb 18, 2025 2:09 pm  (#20)
@Guitarzan
With the plugin in place. If you run the appimage in a terminal you get this error
File "/home/rich/.config/GIMP/2.10/plug-ins/random-downtown.py", line 35, in <module>
import ssl
File "/usr/lib/python2.7/ssl.py", line 98, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: libssl.so.1.1: cannot open shared object file: No such file or directory
Mint 22 comes with libssl.so.3
You can get the plugin to show and sort-of work if you disable line 35 in the plugin eg change import ssl to #import ssl
An alternative is the ivan-hc GNU-Image-Manipulation-Program_2.10.38-2-Hybrid-with-python2-from-Debian-Buster-archimage3.4.1-1-x86_64.AppImage
Much larger appimage, contains the missing file and the plugin works.
